Home > Puma (Tdci) > CAUTION! PUMA & fording
Page 2 of 7 <1234567>
mse
Re: CAUTION! PUMA & fording
lrmaniac wrote:
nakatanenga wrote:
on the PUMA the gearbox breather is NO LONGER in the engine bay! it is just some some cm over the bellhousing!
So if you go fording take care to raise all breathers and air intakes.....
...I read somewhere, long before I bought my 110, that in the Puma there was no need do raise the breathers of the diffs and gearbox ... it was taken care off Question
And when I bought the snorkel there was no breathers kit like my TD5 used to have ... I was told there was no need for it ... Question Question Question Is it ?
You are correct
That was off here and came from mantec i recall Mike
Post #54443 21st Jan 2011 10:30pm
nakatanenga
Germany
We checked 3 different Pumas from 2007 to 20010. None had a gearbox breather longer tha a couple of centimeters!
And it is needed, judging by the oil/water mix in my 130..... WANTED:
SII or SIII in max 1.5k
Post #54484 22nd Jan 2011 9:32am
fordy103
2010 Defender 90 Puma 2.4 HT Zermatt Silver
mine has 3 breather pipes in the back of the engine bay, will check today but assuming thats front axle, gearbox and something else?
Post #54485 22nd Jan 2011 9:57am
MK
Whistle
 Puma 110" SW
Post #54486 22nd Jan 2011 10:11am
mse
Mines the same...gearbox, transfer box and front axle....rear axel is at the back with the fuel tank breather (although since having the new one i have no idea where that is! Mike
Post #54488 22nd Jan 2011 10:34am
mse
MK wrote:
Whistle
other than a gearbox...im not sure what we are looking at there! Mike
Post #54489 22nd Jan 2011 10:34am
Grockle
mse wrote:
MK wrote:
Whistle
Ther than a gearbox...im not sure what we are looking at there!
the grafitti Mike 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #54496 22nd Jan 2011 10:44am
MK
Oh Censored , my mistake. The picture was intended for the NASA forum Puma 110" SW
Post #54512 22nd Jan 2011 12:25pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
So what is the conclusion ? Mr. Green Are the breathers needed ?
what is the solution? Is there a kit available ? Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #54514 22nd Jan 2011 12:43pm
MK
Take the end tube (left side in the pic above) and fit an extension up to the engine bay or further up. Or a non-return valve (eg. AMR6676). Puma 110" SW
Post #54515 22nd Jan 2011 1:04pm
fordy103
i personally dont think its needed, spent atleast an hour under mine today checking this out, and mine gearbox breather is in the engine bay next to the other ones. maybe this small breather is only on the 130? although i cant see why. Just for reference, mines a def 90, 60 plate new from dealer, and i havnt fitted a wading kit or whatever. might ring mantec on monday and ask opinion.
Aparently, even with a landrover snorkel fitted ( as in the mantec one fitted by a dealer), the maxiumum wading depth covered on warrenty is 500mm, which is daft!
probs cause of the ecu placement Rolling with laughter
Post #54586 22nd Jan 2011 7:41pm
Glynparry25
Land Rover don't seal the whole system up, so it is just a Raised Air Intake to keep dust out Wink
Glyn Sheep
Post #54587 22nd Jan 2011 7:46pm
BigMike
Mantec doesnt do a wading kit for a puma. I asked them when i first got mine, he said "not needed". Mine also has breathers of decent length.
but thr 500mm thing is worth mentioning, because when i took mine in because the lower door seals wer leaking, and the battery box was Censored in water, the service guy said "ah yes, not covered, youre not supposed to wade more than 500mm", which is hilarious, since on a LR experience day, in a defender you go over the bonnet in water. Its corporate crap to protect themselves from people use defenders for what they are supposed to actually do. In fact the guy was so snotty about it, he made a note to add to my file "wades deeper than recommnended". I won't be going back there (James Edwards, Brock)
Post #54588 22nd Jan 2011 7:50pm
BigMike
Glyn Sheep
yep, if you want it water tight you have to DIY
Post #54589 22nd Jan 2011 7:52pm
fordy103
also, got snotty remarks at james edwards, when i turned up in mine to complain about a rattly dashboard, and the service guy kept questioning me why i had a snorkel etc etc. On another note, has anybody found a way of making the ECU watertight in a puma yet? sealed both my seat boxes today when i fitted my winch, but wasnt really liking the ecu placement
Post #54590 22nd Jan 2011 7:53pm
