Home > Puma (Tdci) > Egr valve 2.2 puma
Mcd
United Kingdom 2012 Defender 90 Puma 2.2 HT Cairns Blue
Egr valve 2.2 puma
2.2 puma egr removal is this an easy job and does a strip and clean usually work
Thanks in advance
Post #544769 30th Jun 2016 10:01am
Cupboard
If it's anything like the 2.4 Puma it's conceptually pretty easy but access to some of the bolts is tricky and they're probably quite hard to undo.
It took me hours to get mine out, then was very quick to put back in again once I'd worked out the correct angle to put the spanners at. I had two sizes of socket set, flex head ratchets, flex head rings, offset rings... basically most kings of spanner that you could use. Ended up doing the difficult bolt with a standard combination spanner in the end.
Cleaning mine didn't help.
Post #544785 30th Jun 2016 10:30am
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
reguarding cleaning I used Valvoline egr cleaner it worked well . but been told brake cleaner is good too
Post #544816 30th Jun 2016 1:29pm
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Is the EGR valve sitting at the right hand side of the inlet manifold?
I see a flange (2 bolts) at the inlet is that enough or is there a bracket at the underside?
I cannot move anything.
It looks different as the pipe hereunder. It is coverd with isolation webbeding
Post #601981 15th Feb 2017 2:11pm
