![]() | Home > Td5 > Noise diagnosis please |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 987 ![]() ![]() ![]() |
Turbo bearing? Easy to check if the impeller is loose. Take off the hose and wiggle it up down in and out. Should be none. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3321 ![]() ![]() |
There will be a small amount of side to side play in the turbo impeller, as the bearing runs on a film of oil.
But there should be no in/out play and the turbine blades should not touch the housing when you test it with the engine not running. |
plumpmoose Member Since: 14 Dec 2015 Location: North Devon & Oxon Posts: 120 ![]() ![]() |
Thanks, will try and find turbo and the housing you mention:-O and give it a wiggle.
I had a rattling noise off which I thought came somewhere from the front, but it happened to be the exhaust touching the fuel tank support. I found this when my 90 was very dirty and I wondered why that small piece off the exhaust was clean. I fixed it by chaging the exhaust support a little. I was supprised that the rattling noise was gone too. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
@ plumpmoose, When you say "whine", would you say a whistle noise, as in very high pitched, in that case I'd say it's very likely to be turbo related, it could just be something as simple as a split turbo hose or loose clamp, or possibly a slight exhaust leak.
Try changing the gearbox and transfer case oils.
Many "services" never touch these items. And check the oil level in the diffs. My 110 had hardly any oil in the rear diff and it came with a full service history. The rear diff seal often weeps oil and the level drops over time. |
Not high high pitched, but not low either. Noise volume rises and falls with engine revs. Completely stops when out of gear and rolling (with and without engine revs). Will investigate turbo bearing and other suggestions. |
neil.b Member Since: 28 Nov 2016 Location: derbyshire Posts: 7 ![]() ![]() ![]() |
did you find out what the problem was i have something like this
found my problem (wine in tune with engine revs inside the landy it sounded like it was coming from transmition/diffs very loud ) on lifting the bonnet and having someone reving the engine it was clearly coming from the front right did screwdriver check and the top right idler pulley was rumberling so much so that the screwdriver was vibrating about after taking the serpantine belt off the noise disappeared any way removed said pulley would not spin at all removed bearing cheeper than replaceing all the lot noise gone
Excellent! simple fix as well. So many just don't follow up and let the forum know what was up. Thanks. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
