Home > Maintenance & Modifications > My Next Project & Help please (Soundproofing)
Page 2 of 2 <12
Stacey007
I know it may sound daft but even just doing the drivers door, then part of the boot (without the 6mm foam) it already sounded better.
I wish I did a decibel reading before / after. Maybe its in your head?? well actually no as the drivers door now thuds rather than rattles when you shut it... so It is better Smile
Not driven it yet now the boot done and the 6mm foam as only did this in the afternoon will do tomorrow for commute, I will report back Very Happy
Post #543628 26th Jun 2016 8:25pm
Stacey007
Hello
Drove to work today, its not a huge wow difference as if I have suddenly converted it to a normal car, I never expected that. Its better though and thinking what I have done its probably only 25% of the car so far.
Its only the two front doors and rear boot floor with arches I've done.
What I notice more than anything is the way the doors shut with a thud, noticed even more by the back one now sounding like a tin can, so will have to do that soon.
The difference in sound inside so far is slight but better and if I carry on I guess only get better Smile
Post #543990 27th Jun 2016 8:22pm
Stacey007
Started moving forward a little, well over the rear arch behind middle seat on drivers side, Added the silent foam and also 6mm soft cell.
I've covered more of the car at the side than the current carpet covers however with the black soft cell on top its not as obvious when the carpet is missing however I may buy some extra carpet and spray glue to hide it completely.
Sides covered,
Then the soft cell on top
I can see why to have this done could cost £1300 upwards on a 110 as there its very labor intensive. However I'm enjoying it and spending and hour or so in the evenings is quite therapeutic...
Smile
Post #544312 28th Jun 2016 9:25pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
did you take out the middle row seats?
Post #544347 28th Jun 2016 10:41pm
Stacey007
Hello
Was going to but googling it and looking at the job you can get to everywhere with out. Taking them out seems to just add to the job and I need the car as a daily transport.
This bit which even when you take the seats out is the only bit I haven't covered (the yellow box area), I've literally got silent coat and soft cell but up against this seat mount.
It makes the job a little harder maybe? more cuts and move the seats back and forth but peel back the carpet remove the foot well carpet and you can get to everything. You might have to squeeze your hand into some tight corners but using the roller to squash the silent coat down it works well.
I actually enjoyed (sad maybe) cleaning the floor prior to fitting and its like new before I add the silent coat.
Post #544445 29th Jun 2016 11:25am
Stacey007
Been a bit too busy lately to do much but had a spare couple of hours today.
Cleaning up the bolts and underneath.
Took the bolts out and fitted the stainless rear sill also.
Covered more parts than I have carpet for but I also have 6mm closed cell to go on top and then will get some extra carpet to cover also. So the bits of silver will be hidden (the face of the silentcoat)
All back together
Also did the fuse box under drivers seat and the lid for it, including part of the area round the pedals and the gear stick, Carpet was a pain to remove around this area Smile
Post #549181 16th Jul 2016 7:17pm
bm52
Looks good. I have now done under middle row and put 6mm foam under seat box lids.
Made a big difference.
Next will be rear tub but will have to wait until back from body warranty work for roof seal replacement.
I have all the stuff I need to complete everything. It will just take a while 😕
Post #549197 16th Jul 2016 9:18pm
bm52
Post #549198 16th Jul 2016 9:20pm
Stacey007
This is the box under the drivers seat as I started covering the sides and base as much as I could,
The bottom of the kid I put silentcoat (the big sheet on the left)
I may well put some soft cell on top as that's 6mm, I guess these box's do boom the sound out.
Under the passenger mats will be 6mm soft cell also I just need to cut it.
It has to help I guess Smile
Post #549204 16th Jul 2016 9:36pm
Stacey007
Gardening got the better of me today but still managed half an hour or so to start the passenger side seat box.
Took the tools out, cleaned them, cleaned the box, (will take battery out another day)
Started the silentcoat
one big sheet on the base of the seat lid
so a bit more done, managed to squeeze some at the side of the battery but will have to take it out to do a proper job.
Post #549384 17th Jul 2016 8:54pm
Page 2 of 2 <12
