Home > Technical > Back door lock
90roy
Back door lock
Hi there,
Does anyone know if there is a modified back door lock I can buy which will accept a power door lock solenoid?
I cannot see that I can one to the standard unit I have and it appears to be fully sealed and I cannot gain entry.
Thanks in advance,
Roy 300tdi 90 1996.
Post #543642 26th Jun 2016 8:47pm
Retroanaconda
You can buy the later 2002-on variant with the attachment for central locking. Only problem is that it uses the later longer barrelled key, so you'd need to change that too.
Alternatively you can split the old lock (drill the rivets out) and attach a rod inside, or I've seen people attach it to the locking tab on the inside too.
Post #543646 26th Jun 2016 8:54pm
90roy
Cheers retroanaconda. If I split the lock, how do I join it back together again?
Will the later locks go on to my door without me having to modify it?
Cheers. 300tdi 90 1996.
Post #543718 26th Jun 2016 11:20pm
Retroanaconda
Some small countersunk screws/nuts can be used to re-tighten it. Beware of springs going boing if you open it though!
Yes the new style will fit, the rear door lock orifice is the same right from present day back to the Series 2 in the late fifties.
Post #543755 27th Jun 2016 6:33am
miker
The repair kit I bought for mine the other week (locking spring breaks) came with pop rivets to hold it back together. Seems to work just fine!
Post #543799 27th Jun 2016 10:21am
90roy
Hi miker, where did you get that kit from? 300tdi 90 1996.
Post #543945 27th Jun 2016 6:41pm
miker
eBay! About a fiver,
defender safari door lock repair kit.
Post #543955 27th Jun 2016 7:15pm
90roy
Post #544054 27th Jun 2016 11:50pm
termohe
Belgium 2004 Defender 90 Td5 HT Alpine White
Door lock with central locking FUB500060,
Post #545300 2nd Jul 2016 12:28pm
