Home > Puma (Tdci) > Torque on pulley bearing bolt -2.4 serpentine belt tensioner
agentmulder
Kuwait
Yeah gidday, I want to remove it.
So it's not the bolt that attaches the tensioner arm:
But the bolt that hold the pulley bearing (and pulley) in place. On the right here:
WSM, don't have it!
Perhaps just do by feel, and add some threadlock?
Interestingly, it looks like it's been removed previously (I'm third owner) Solved the bowel problem, working on the consonants...
Post #542877 24th Jun 2016 12:35am
AlanH
Australia
Has the pulley got worn bearings or something requiring it to be removed? If it has and you replace them OK I wouldn't bother too much about a tension wrench just tighten well as per normal and if you like use a touch of Loctite or similar.
AlanH.
Post #543474 26th Jun 2016 9:59am
agentmulder
Kuwait
Yes, yes and yes Thumbs Up
Done. Solved the bowel problem, working on the consonants...
Post #543515 26th Jun 2016 1:22pm
