Home > Td5 > TD5 steering pump modification
big ives
Hello
Circled in RED I would like to remove this fitting and bolt on a fitting that would allow me to use a threaded connection on the low suction on this TD5 steering pump what could I use???????
I DO NOT like jubilee clips on the hydraulic hoses and would like something more secure hence thinking about a threaded connection (this will be fitted to an extreme off road landrover)
Cheers Bow down Bow down Bow down Bow down
Better with the picture attached Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter please see below Thumbs Up Thumbs Up Thumbs Up not good on the computer Embarassed Embarassed Embarassed Embarassed Embarassed
Post #542999 24th Jun 2016 1:55pm
big ives
Post #543001 24th Jun 2016 1:57pm
rallysteve
Cant see what the issue is with a jubilee type clip on a suction line. If you are particually adverse to that type of fitting i would advise you get a piece made up with a threaded JIC type fitting attached. I wouldnt tap and thread the housing to fit a fitting as the reduced bore size will no doubt cause pressure drop and possibly cavitation. 02' 110 TD5 Double Cab Rebuild Thread
Post #543008 24th Jun 2016 2:29pm
lightning
Jubilee clips are fine as long as you use the good ones, where the clamp is recessed into the screw part, so it's perfectly round.
Post #543023 24th Jun 2016 3:21pm
dorsetsmith
jubilee clip are ok on the low presser side of the pump
Post #543081 24th Jun 2016 6:26pm
big ives
thanks for the reply's
as I said its going on an offroad extreme landy, I had issues before on a previous pump where the hose came off in the middle of a section AND DUMPED ALL THE HYDRALIC FUILD, was hoping to fabricated a fixed threaded connection
will once again try the good quality hose clamp........................................cheers
Post #543198 25th Jun 2016 3:51am
dorsetsmith
make shore your hoses are in good order too Exclamation
had same problem with leaks on the power steering low presser side hose tall, replaced one length of pipe work and new jubilee clip leaks sorted Thumbs Up
Post #543220 25th Jun 2016 9:16am
