Home > Maintenance & Modifications > LRDirect - Britpart 'OEM' vs. Britpart standard ?
agentmulder
Kuwait
Alright so what's the difference between Britpart 'RUC105200.C8' for �4 and Britpart 'OEM" RUC105200G.C8 for �12 ?
Both listed here:
https://www.lrdirect.com/RUC105200-Drive-F..._https=yes
Yes, LRDirect sent me 4 blue boxes when I ordered RUC105200G.C8 Evil or Very Mad Sad
Apparently that is what 'Brand: ORIGINAL EQUIPMENT' means...
I didn't expect genuine, but I certainly didn't expect Britpart.
Is there actually a product difference?
I would have gone Bearmach had I known! Solved the bowel problem, working on the consonants...
Post #542647 23rd Jun 2016 8:25am
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Britpart OEM is open to much interpretation...
IME, when using OEM suspension arms, they fit OEM bushes into their own arms
However, when using something like a drive flange, OEM is OEM. They use the same blue box for packing Thumbs Up
Post #542648 23rd Jun 2016 8:28am
agentmulder
Kuwait
So the flange is made in another factory, with better processes, better materials and better final inspections and tolerances and Britpart just have a finger in the distribution pie?
Even if it is better than the �4 version, they're so bad as a brand I just don't care... Solved the bowel problem, working on the consonants...
Post #542650 23rd Jun 2016 8:35am
Disco_Mikey
A Britpart OEM drive flange is the same flange as you would get from a main dealer, but at 10% of the price Thumbs Up
Post #542651 23rd Jun 2016 8:44am
agentmulder
Kuwait
The same flange?
Same factory, same run, same allowed tolerances? Solved the bowel problem, working on the consonants...
Post #542652 23rd Jun 2016 8:49am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I've chanced a few things before that were labelled as Britpart OEM and they have been fine, wheel bearings were Timken branded, a clutch was Valeo and a clutch slave cylinder was Lucas albeit all in blue boxes.
On the other-side I don't trust Britpart's own kit as far as you can throw it. The last slave cylinder I bought in desperation was cast so badly it wouldn't fit inside the bellhousing!
You should be fine with Britpart 'OEM'
Post #542657 23rd Jun 2016 9:17am
Disco_Mikey
^ Thumbs Up
Post #542659 23rd Jun 2016 9:23am
agentmulder
Kuwait
Alright, I work with them.
I opened one up and FWIW it did seem/feel like a reasonable piece of engineering.
But just to drive the point home - here is a Britpart plib PCB I opened up today straight from the supplier:
Solder flux mixed with melted plastic and what looks like pubic hair.
I did PCB manufacturing in a past life and I know the flux can be messy, but there are solvents that can clean it. The kicker however, is the three broken solder joints (circled), so much so that the battery holder is completely loose. It makes me think the part is used.
It looks super similar to the genuine part I have here. Hrrrrrm Neutral Solved the bowel problem, working on the consonants...
Post #542662 23rd Jun 2016 9:35am
Mo Murphy
OEM means it was made by a supplier who supplied the factory at one time but does not mean it is made to the same standards as the original. It certainly does not mean genuine in a different box. If you expect that, you'll be disappointed.
50 Shades of Pennine Grey
Post #542879 24th Jun 2016 3:50am
agentmulder
Kuwait
Probably the outcast units from the original production runs... Solved the bowel problem, working on the consonants...
Post #542880 24th Jun 2016 3:54am
nickhodgson
If the one on the car is genuine - do a visual comparison. My experience is that the better flanges (closer to Genuine) have an HRCxxxx number stamped on the inside of the drive member.
I have used a number of Britpart OEM (late style) drive flanges and they look to be good quality. But remember lots of these parts are ordered in batches and the batch you have could be different to the batch I have.
Also the latest parts for the wolf/P38A rear diff in a defender have a solid drive member/axle shaft much like an older 90 or Disco. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #542968 24th Jun 2016 11:53am
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
There seems to be an assumption that genuine parts are all high quality ? If that was the case then we'd not have to spend so much time sourcing replacements or fixing the damn things !
Britpart OEM is normally as good as the genuine part, of course the genuine part may also be carp, especially if it also has a Lucas label somewhere on it. Genuine Land Rover Lucas parts have always suffered from being unreliable PoS manufactured to extremely low tolerances, they didn't get the "Lucas, prince of darkness" tag for nothing. http://www.yorkshireoffroadclub.net/
Post #543012 24th Jun 2016 2:49pm
agentmulder
Kuwait
These flanges have the casting 'stamp', either way they've gotta be better than the flanged shaped iron oxide on the vehicle at the moment.
I guess the LR genuine cant be 10 times better can they??
(I'll try to remind myself of this logic on the side of the rd when the Britpart ones fail Rolling Eyes )
Post #543197 25th Jun 2016 2:22am
spudfan
Ireland
My Defender came with a genuine Land Rover bumper which was replaced due to corrosion. The genuine brake vacuum pump had to be replaced. The genuine clutch was replaced twice. The genuine headlight levelling unit was replaced. The genuine hazard warning light switch was replaced. The engine was replaced. Yep...you pays your money and takes your choice. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #543376 25th Jun 2016 7:16pm
