Home > Maintenance & Modifications > bmw 3.0 into a defender. ....
Page 2 of 2 <12
MuddyChris300tdi
United Kingdom 1995 Defender 130 300 Tdi HCPU Alpine White
I started to look into the M57 conversion a while ago. As far as I know the best engine for it is the 3.0d pre 2004. It can be run on the original ecu with a wiring loom from rally raid. You need a p38 manual gearbox bell housing and input shaft fitted to a defender r380. The td5 r380 are apparently a bit stonger than the tdi or syncro gearboxes can make a super strong r380 if your worried. A standard transfer box will be fine with the extra torque of the m57.
Post #542902 24th Jun 2016 7:21am
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
The M57 will bolt upto the V8 Auto HP22 just fine. Turn it into a HP22/24 htbrid and it should cope with 250. Not much more though.
Rallyraid loom and you're away.
You can also buy a bolt-in conversion for the OM606/605 that again, bolts up to the V8 Auto box or V8 Manual box (2 different kits). Again limited to power though.
Then you can either get an original ECU unlocked to run standalone, or go completely mechanical using the pumps from the previous generation. Both available with various element sizes based on power needs. Stock turbo will be good for 230-250hp.
Post #542940 24th Jun 2016 9:41am
taazzukcb
The 'L' suffix R380 is the strongest.
As to the transfer, there's people running massive power and torque through them over in the US. Pretty much stock too. One of the strongest bit LR made, ha!
Post #542941 24th Jun 2016 9:43am
s410man
big steve wrote:
Transit is the engine needed
Excuse the stupidity but why not a 3.2 ranger engine? ?
i thought they were the same? ?
cheers
Post #545009 1st Jul 2016 8:39am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Completely different manegment system engine is the same but you would need to fit transit injectors and get the transit wording and ecu
It is easier to start with a complete 3.2 transit if you can 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #545070 1st Jul 2016 3:17pm
Page 2 of 2 <12
