Home > Maintenance & Modifications > Water drops under car on passenger side near front?
Stacey007
Any idea?
Only drops but enough to see on the floor.
I looked under and cannot see where its coming from, no A/C on so its not that.
Its on the side of the Screen wash and that is full, what side is the expansion for the radiator on?
It's not showing a higher temperature than normal on the ultra gauge? could it just be water trapped in the wing vent? it doesn't matter if car is parked flat or on a hill.
Thanks in advance.
Post #542518 22nd Jun 2016 8:13pm
K9F
http://www.defender2.net/forum/topic39043.html?highlight=teat
http://www.defender2.net/forum/topic30325.html?highlight=teat If you go through life with your head in the sand....all people will see is an ar5e!!
Post #542529 22nd Jun 2016 8:39pm
Stacey007
^ I have not got the A/C on though?
is it still the Same?
Thanks
Post #542531 22nd Jun 2016 8:45pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
I'd stick money on it being water from the screenwash bottle. Mine does exactly the same. Empty the screenwash by half and see if it still does it Thumbs Up 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #542608 22nd Jun 2016 11:25pm
K9F
You don't need it on. Water builds up and has nowhere to go but into the footwell. You could spend 3-4 minutes having a look which will take a lot less time than having a debate and waiting for answers perhaps? Rusty's idea sounds good too. Build up of crud in your windscreen seal is also plausible and happened to me. Good luck.
See page 2 and Fekete's long on-going issue. Unfortunately this is a windscreen out job to cure it.
http://www.defender2.net/forum/topic2126.h...p;start=15
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #542638 23rd Jun 2016 7:37am
Stacey007
Thanks K9F
will get under and look
I'm not overly worried water levels all appear fine, and temperature on gauge seems normal.
Thanks again
Post #542681 23rd Jun 2016 10:46am
K9F
Let us know how you fair and as mentioned good luck! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #542718 23rd Jun 2016 1:06pm
Andrew*Debbie
Re: Water drops under car on passenger side near front?
Stacey007 wrote:
Any idea?
Coolant and screen wash should smell. Neither are just plain water, unless you filled up with water.
Could it be rain water?
Ours is letting in rain and it ends up on the passenger side floor.
Post #542733 23rd Jun 2016 2:00pm
dorsetsmith
(rain water) at lest you no its genuine think Rolling with laughter
Post #542734 23rd Jun 2016 2:04pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Is it the same side as the cabin air intake?
There is a drain hole in the bottom of the air box that lets its contents run down the back of the wheel arch and onto the floor. The position of the drain valve (rubber gromet thingy) on my 300Tdi means that it drains fairly slowly even when cleared out of the leaf mould that likes to lurk in there. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #542740 23rd Jun 2016 2:54pm
K9F
One of the modifications suggested in the links I posted previously suggests cutting said grommet to allow better drainage.
Post #542748 23rd Jun 2016 3:27pm
Andrew*Debbie
Nevermind.
Post #543025 24th Jun 2016 3:29pm
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
I'd go with the screenwash suggestion, mine does the same if topped up.
Post #543038 24th Jun 2016 4:08pm
nitram17
Please look at your air duct connection to the blower from the nearside wing:
http://www.defender2.net/forum/topic47380.html
is it like Def 90s?
other sites of leak you may know are 1.. Windscreen rubber solution seal it 2..Bulkhead foam seal solution seal it with tiger seal of or captain trolleys. 3.Fake windscreen bulkhead hinges ...i think the seals are paper based... solution replace and seal with tigerseal.4.Some of the grommets that allow the wires to pass through bulkhead..solution seal with tape!if the screen wash is at fault make sure by using coloured screen wash and see if it on the mat.....is your truck parked on the level or is it tilted to one side slightly so water runs towards the passenger side!
Post #544260 28th Jun 2016 6:46pm
