![]() | Home > For Sale & Wanted > [Wanted] Front middle seat |
minicab Member Since: 21 Jun 2016 Location: Kingston-upon-Thames, Surrey Posts: 11 ![]() ![]() ![]() |
Hello
I just got my very first Defender and I am thrilled to bits. However there are a few small jobs to do and would appreciate any advise/help. 1. I need a front middle seat complete preferably tweed but vinyl is ok. 2. How to convert it from a pick up truck into a soft top? 3. I just got it...so it will take a while... Thank you. Minica |
1978 Member Since: 04 Aug 2015 Location: Lancashire Posts: 519 ![]() ![]() ![]() |
Its a great feeling isn't it!
Exmoor trim are your friends with the first couple of points, front middle seats are here in matching fabrics: http://www.exmoortrim.co.uk/store/defender...etail.html To convert to a soft top you will need a tilt (hood) and sticks (frame for hood). There are a couple of options for the sticks, I would go for the XS heavy duty version but they're a bit more expensive. http://www.exmoortrim.co.uk/store/defender...etail.html http://www.exmoortrim.co.uk/store/defender...etail.html http://www.exmoortrim.co.uk/store/defender...etail.html You can no doubt sell the truck cab you have to recoup some of the cost. |
Many thanks 1978.
Will look into it. Would you have anything to go with a pick up truck? What I meant was to keep the cab and add a hood on metal sticks at the back. |
No problem, I am not associated with the company in any way, but they are highly regarded for hoods and seats etc.
If you want to keep the cab, you would need: http://www.exmoortrim.co.uk/store/defender...etail.html and http://www.exmoortrim.co.uk/store/defender...etail.html There are a few options, so probably best to give them a call to ensure you get what you want. |
LEZ Member Since: 22 Oct 2015 Location: London Posts: 169 ![]() ![]() |
PM sent.
Hi LEZ
I can't use PM yet (not enough posts rule...). Have you got a price in mind? Thanks Minica |
ofc, soz, can you call me on 0208-467-1839 ?
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 729 ![]() ![]() ![]() |
Like this?
![]() Click image to enlarge Cheers Alex 98 300 tdi 90 project 88 200tdi project soft top 96 disco 1 jap import 79 911 sc 08 130 double cab utility |
Yeeees! That's the one! Well, I got a 110 in Coniston Green...
I had a look on Exmoor side but still can not see the difference between the cab fit and body fit ? Any closer pictures to the connection with the cab? Thanks Minica |
You need a bar that rivets onto the cab that the canvas is trapped by.. Too many tools in the back to show you inside but here's outside shot
![]() Click image to enlarge Hth Cheers alex 98 300 tdi 90 project 88 200tdi project soft top 96 disco 1 jap import 79 911 sc 08 130 double cab utility |
Thank you. It does make sense now. Would the canvas next to the cab obstructs in any way the back window from the cab?
No worries, no it sits 40/50mm below the window...
Cheers. Alex 98 300 tdi 90 project 88 200tdi project soft top 96 disco 1 jap import 79 911 sc 08 130 double cab utility |
Many thanks to Lez for beeing so kind. I got one now.
