Home > Technical > Rear propshaft
MK
Rear propshaft
ladies
on the 110" is the rear propshaft in-phase? or also at 30º
thanks
MK Puma 110" SW
Post #54240 20th Jan 2011 10:50pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Not 100% sure about the Puma but on the TD5 is in-phase (i.e. each joint at 90 degrees). I believe this is because the output of the transfer box and the input of the diff are parallel, where as the front it is not parallel. Also the front axle moves in a arc and the rear in a more linear motion.
Pete.
Post #54273 21st Jan 2011 8:08am
MK
You are right about the Td5. How is it in the Puma 90"? Puma 110" SW
Post #54275 21st Jan 2011 8:54am
