![]() | Home > Maintenance & Modifications > Stiff choke cable |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 ![]() ![]() |
Disconnect the cable at the carburettor end and check it.
This will tell you if it's in the carby linkages or the cable. If the cable feels all right lube and free up the carby linkages. If its still tight check for tight angles in the way the cable is routed. I also used to spray CRC/Penitrine into the cable to lube the inner. Cheers, Kyle. |
charcoal Member Since: 28 Jul 2014 Location: Hampshire Posts: 942 ![]() ![]() ![]() |
The cable is brand new, after removing the old cable and had a fiddle with the linkage and it seems like that is the problem. What should I use to lubricate the linkages? 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold 1995 Land Rover Defender 110 V8 Station Wagon ~ Sold ![]() 1985 Land Rover 110 ex mod project Tithonus ~ Sold ![]() |
