![]() | Home > Td5 > TD5 2001 door switch hook up |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
has it not got land rover alarm fitted ?
Click image to enlarge drawing shows wiring in places for door switches and in side cab roof light Last edited by dorsetsmith on 16th Jun 2016 9:01pm. Edited 1 time in total |
| MC84 Member Since: 23 May 2016 Location: Near Bristol Posts: 360
Well strictly speaking its not an alarm I'm fitting its a tracker. The Defender does have the normal "green box" but that is switched off in the system I believe with respect to blipers.
"green box" anti-theft-alarm / engine immoralism . can be activated , save lot of wiring
sounder alarm battery backed / key fob http://www.fcx.co.uk/#!product/prd1/445939...cation-kit |
Thanks for the info DoresetSmith.
Before I started I had a good look on the forum and it seemed few people rated the Land Rover system saying it was easy to bypass. Personally I would have given it a go but I would have either had to pay a dealer to turn it on or by a Nanocom or similar. I favor the latter but the cost is prohibitive at the mo. I'm intrigued by you attached drawing. Is the complete PDF available for download somewhere as it would be particularly useful? Thanks again for your help, Mike |
Thanks for the links DorestSmith, very useful
