Home > Maintenance & Modifications > Dual Battery Installers
acuss01
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Looking to have a twin battery system fitted on our Puma for holiday next month. Wondering if anyone can recommend a suitable workshop in or near London? I usually use Chris at CSK but unfortunately he's not available for 1 month.
Spec is likely to be:
2 x Odyssey PC1500
Twin Battery Tray
Blue Sea ML-ACR Relay
Blue Sea 6+6 Fusebox
4 x 12v Socket
Merlin SmartGauge Display?
Feel free to comment on my spec as I am a new learner on the subject! 2015 110 XS CSW Montalcino Red with Black Pack
Post #540364 15th Jun 2016 11:38am
Happyoldgit
Any competent, qualified, local auto electrician ought to be able to install that lot where you want and how you want, doesn't have to be a Land Rover specialist either. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #540375 15th Jun 2016 12:07pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
http://www.africaland.it/forum/viewtopic.php?f=27&t=78288 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #540386 15th Jun 2016 12:25pm
LoveTheMud
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
Not sure if any of the kit above has this included, but one thing I am going to wire into my setup is a manual cut-off switch for the spare battery wiring...
Basically, most of the normal stuff runs as intended off the main battery, but i wanted to be able to run a fridge off the leisure / second battery when the fridge was there, but also be able to turn all things off when not in use...
Just a thought
Post #540390 15th Jun 2016 12:34pm
Speak to Tim at Mobile Centre
Post #540414 15th Jun 2016 2:17pm
miker
Unless your running a winch through it I'd bin off the Blue-sea relay and get a Durite VSR.
Also the merlin smartguage looks to be more than you'd need for running a fridge. I'll be honest, I have a £3 ebay voltmeter for keeping an eye on my two batteries, and that works fine for getting a rough idea!
What sort of loads do you want to run and for how long?
What battery do you have now and how old is it?
Post #540484 15th Jun 2016 6:04pm
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
My personal set up is a Albright relay with a on off on switch. On1 is both batteries linked On2 both batteries linked but only when ign is on . this gives you the option to jump start your self should you leave the lights in or Battery 1 dies. You could wire in a VSR and then have a bypass switch.
I have a Madman EMS2 that monitors the engine Inc Voltage on Battery 1 then a cheap eBay cigarette socket size LED display that does Battery 2 wired through a switch
Post #540572 15th Jun 2016 9:53pm
