![]() | Home > Maintenance & Modifications > New Roof Liner |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 ![]() ![]() ![]() |
40 views and zero comments!
It is me ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2028 ![]() ![]() |
Tank,
A few of us have done this mod. Myself and Butchers Boy have both written about it. Have a look in the My Defender threads for our names. My advice: Soundproof and insulate the roof panel while its bare. Get a load of fir tree clips and some extra long ones (what type of headlining are you putting in?) Are you doing a full length or just truck cab area? 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
re the rear view mirror riv nuts - theres not a LR out there where these are well fixed. Do you mean they are spinning around?
The only fix is to tighten the existing ones or replace. You will need a rivnut tool but these are cheap off ebay. In order to remove the screws with a spinning riv nut you need to grab it/ clamp it from behind somehow, sometimes you can do this with your fingers, then unscrew the screw. Some WD40 makes this easier. The easy way to get at the rivnuts afterwards is to drill out the 3 rivets holding the bracket to the windscreen frame and get at it on the bench. If you can describe more what state yours is in, I can help more. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Thank RRUK
It's the full thing I am doing in a Truck Cab 90. Its the OEM Land Rover head liner from OEM Landrover. Looks well made. I have the Rivnuts and two friends offered me the Rivnut tool to use. Hopefully easy ![]() I have just put the MudStuff plastic side panels in and I am worried I might have to take these off to get the headliner in. I am dynamating the whole truck, roof included. Will look you up on Def2 and see your post. Many thanks TANK |
Tank,
Do you mean you have a hard top with a roof lining currently only over the truck cab area, or do you have a truck cab model? http://www.defender2.net/forum/topic38640-285.html I also fitted the MUD side panels in my previous 90. From memory you'll need to remove these to do the headlining. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
