Home > Maintenance & Modifications > Creaking headlining
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Creaking headlining
I have just ordered some new genuine fir tree clips to try to solve this problem. (I have had the headlining out a couple of times and reused some clips and used britpart clips as replacements.)
I also put the aluminium strips that go above the rear doors in the wrong side and they were really noisy. Swapping them round solved that problem.
The noise is coming from right next to your ear on the passenger side...really annoying. So, before I replace all the clips for genuine has anybody any suggestions to prevent the noise? Maybe some sort of lubricant between the roof and the headlining. Seem to remember talcum powder used to be used as a fix for squeaking floor boards Laughing 2002 110 td5
Post #539673 12th Jun 2016 6:49pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Teflon or silicone spray works wonders. There are many different versions and brands on the market....
https://www.amazon.co.uk/One-Professional-...B000297TQM 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #539706 12th Jun 2016 8:29pm
Rickydodah
Re: Creaking headlining
Not sure that this is of any help but, I too had the headlining out for soundproofing, replaced with new fir trees and okay for a couple of days until this creaking started, even when stationary. Removed the plastic shroud running down the B pillar, packed with foam and replaced, creak gone, until today.....anyway after many attempts it still remained. The only thing I could think of was if the door was flexing in the opening it may cause this issue. So, I adjusted the door striker so that the door closed tighter, et voila, creak gone. This may be a complete red herring of course but I too had no noise before the headlining was removed. Good luck Thumbs Up I started with nothing and still have most of it left!
Post #539732 12th Jun 2016 9:28pm
Jimb1978
Thanks for the suggestions. I will try both of these this week and let you know the results Thumbs Up 2002 110 td5
Post #539741 12th Jun 2016 9:53pm
Jimb1978
Adjusted the door strikers and it is a million times better. Thumbs Up 2002 110 td5
Post #542217 21st Jun 2016 10:09pm
