![]() | Home > Technical > Puma dash fault |
Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178 ![]() ![]() ![]() |
First problem is the jump start. You need a fully charged battery that the ECU feels all warm and cuddly with.....nothing wrong with the dash in all likelyhood! Get a new battery or recharge the old an install following the proccedures in the manual. The electrics in these vehicles are not like the old ones!
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
I'd also add leave the battery disconnected completely for half an hour too, then with battery completely removed touch the earth terminal to the live terminal as well.
That should drain absolutely all residual power and then once a good fully charged battery is back in and connected up you should be good to go |
cutts Member Since: 06 May 2016 Location: UK Posts: 36 ![]() ![]() |
Fantastic news guys, hope it's that simple after having s maze of electrical problems on my bmw..
Will report back! Not even picked her up yet but I've started buying parts! |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Welcome to the forum.
You will have to put pictures up when you get it home ![]() |
Didn't try your fix due to taking ages for them to sell it! So the battery went flat, and they charged it.. All lights gone! Thanks guys looks like your diagnostics was spot on- I've got a lot more work on the horizon
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
In one of your rounds of buying stuff, get yourself a Land Rover diagnostics doodah. They can be a great help and don't have to cost the earth, basic ones start at about £100.
