Home > Maintenance & Modifications > which swingaway
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
which swingaway
Right,
Binned the spare wheel carrier off the back door of the 110 last year and the spare has been relocated into the 'boot'. Getting a bit frustrated withboth amount of space a 255/85/16 takes up in the back and also concerned that should I have the misfortune of picking up a puncture when laden- everything has got to come out to get to the spare!
So, looking for a swingaway carrier to take the spare but that is also compatible with a set of Bumperettes- I don't mind modifying them a touch though if needs be.
So ladies and gents, your recommendations please?
Price and durability arrange the key issues for me!
Chris
Post #538687 8th Jun 2016 9:40pm
nitram17
have you got the bumpwtters in place?if not try here-
http://www.safari-equip.co.uk/pages/landrover-defender/
http://www.safari-equip.co.uk/shop/index.p...rrier.html
http://www.safari-equip.co.uk/shop/index.p...umper.html
look at the safari bumpette and single pivot wheel carrier!
Post #538698 8th Jun 2016 10:01pm
StephenO
I just bought and fitted one of these, very happy with it and it's a sturdy piece of kit for the money. 👍
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...SwnLdWteaj 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey
1968 Series 2a Bronze Green
1995 Defender 90 Coniston Green
2005 Discovery 3 Zambezi Silver
Post #538702 8th Jun 2016 10:07pm
MartinK
Lots of us got Nakatenanga Stainless ones from Brendan (4x4 Overlander - sponsor on here) as a group buy.
http://www.4x4overlander.com/product/stain...post-2002/
Bolts to crossmember only.
Really good piece of kit..
I had to modify my Safari Equipe Bumperettes slightly....
superb piece of kit, but slightly pricey... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #538750 9th Jun 2016 6:38am
leeds
Swingaway wheel carriers?
There are two main types, basically those which bolt onto the rear cross member and those which require the rear tub drilling.
If you do not want to drill the rear bodywork then it is a single pivot wheel carrier.
We at 4x4 Overlander offer probably the widest range of swingaway wheel carriers in the UK.
In my mind the best swing away wheel carrier is that by Nakatanenga, made from stainless steel, single pivot available for pre and post 02 Defenders, also for pick ups and also for D3/D4
The Safarie Equip mild steel single pivot wheel carrier and the range of standard Safari Equip wheel carriers for Defenders, pre and post 02, with or without high lift jack mount and for pick ups. Available galvanised or just plain mild steel.
We have many of them in stock.
Brendan
Post #538812 9th Jun 2016 12:36pm
nitram17
How did youmodify it ?it looks like you made the inner leg longer! .....would it not have been easier to fabricate a spacer?No welding involved!
Post #538939 9th Jun 2016 9:49pm
tobz102
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Run the mantec classic myself that i'm particularly happy with..Especially the quality of the powdercoat. No sign of rust and fitted for 3 years now
Post #538940 9th Jun 2016 9:52pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
+1 for Nakatenga stainless, this is number 2, first one saved 110 from total write off by a truck Thumbs Up
 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #538959 9th Jun 2016 10:43pm
familymad
Brendan is right, a lovely thing that single arm one. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #538990 10th Jun 2016 6:15am
FunkyMunky
United Kingdom 1996 Defender 110 300 Tdi CSW Alpine White
Bought the same one. Sturdy bit of kit but decided to use mild steel nuts on the hinge bolts and welded them together for security. Wink
Stu
Post #539197 10th Jun 2016 7:26pm
LoveTheMud
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
To be honest, I have a mantec, it looks good but i've had to tighten it up twice now in 2 weeks of having it... it rattles loose and has a nylon cylinder to control the movement, being nylon means you cant tighten it up enough. To tighten it you need to remove the spare wheel.................. Big Cry It does hold the door where you left it, even in a strong wind...
Post #539199 10th Jun 2016 7:31pm
FunkyMunky
What is it that comes loose?
Post #539205 10th Jun 2016 8:01pm
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
Another vote for the Nakatanenga wheel carrier, We have one on SWMBOs soft top 90, top quality engineering,
a thing of beauty. 2010 Defender 110 Station Wagon, Santorini Black.
Post #539254 10th Jun 2016 10:00pm
LoveTheMud
It's the locking nut against the plastic nylon cylinder, I will take some photos tomorrow as I realised its come lose again today so I need to drop off the wheel and tighten it back up.
Post #539300 11th Jun 2016 12:39am
FunkyMunky
mine has 2 nuts/washers on the threaded rod that goes into the nylon, one of each either side of the bracket and tightened once the threaded rod/nylon travel distance is set.
Tried to get a picture but phone won't fit in!
This is the one I have, instructions...... http://www.slideshare.net/JoaoCarreira2/da22321?next_slideshow=1
Any use?
Post #539392 11th Jun 2016 3:31pm
