Home > Technical > Help Please - Puma 2.2 tdci Fuel Pressure Regulator Replacem |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6265 |
to the bet of my knowledge the rev should be about 800 +/- 20rpm on tick over once at temp.
could an egr passing also cause the erratic idle? |
6th Jun 2016 2:41pm |
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 |
Ah - no - you misunderstand me. I wasn't clear enough.
My tick-over is stable - it's the fuel pressure that's erratic at tick-over. I believe it should be about 200bar but not sure whether that is a stable 200 or one with peaks and troughs!!??!! |
6th Jun 2016 2:44pm |
I believe the pressure etc is erratic. as the VCV opens / closes but hopefully someone can confirm?
6th Jun 2016 2:46pm |
Update - apparently it's now called the Fuel Vapour Valve (FVV) - Part No: LR079825.
Anybody know the symptoms if this part fails? |
6th Jun 2016 3:22pm |
xpertoftheseas Member Since: 05 Jan 2016 Location: Salisbury, Wilts Posts: 164 |
Can you clarify what you mean by "Surging"? At no load, in neutral on idle, is the idle smooth and constant rpm, or rough and varying rpm?
When under constant load (pulling in 3rd gear, with foot on throttle in a constant position), is the car acceleration constant? The fuel rail pressure will be constant at non-changing RPM, as the rail is designed to absorb the pressure changes when fuel is taken from the rail. The pressure in the rail is controlled by the ECM and is varied by the HP fuel pump dependent on engine load and RPM. You state that the FRP sensor has been replaced? Just for clarity this is the sensor that is at the end of the HP rail, correct? I only ask as I thought this sensor could not be changed with changing the entire HP rail. I have some pictures but right now the site will not let me upload due to a fault. If you can advise on the above we can take it from there. My 10th Land Rover, but my first Defender. |
7th Jun 2016 8:48pm |
I don't think the frp sensor has been replaced. There is mention of replacing the vvc which I believe is on the back of the pump.?
7th Jun 2016 10:24pm |
In this case, where the sensor has not been replaced, then this should be the first item to look at.
Idle Pressure - 220-250Bar Driving Speeds - 1300-1600Bar However, fast fluctuations outside of these pressures at fixed loads/no load in rail pressure can be caused by several things - failing injectors (slow open/close, leak back valves passing etc), failing HP pump (would cause lethargic response and lower powers, most definitely triggering different fault codes), passing pressure relief valve etc. The fuel rail pressure sensor is key to ensuring the correct fuel pressures for varying loads and demands on the engine and for emissions control. From the Workshop Manual.... The FRP sensor is located in the end of the fuel rail. The sensor measures the pressure of the fuel in the fuel rail. This input is then used by the ECM to control the amount of fuel delivered to the fuel rail. If the FRP sensor fails, the engine will operate at reduced power and a DTC (diagnostic trouble code) will be triggered. The sensor is not serviceable separately, and comes as part of a new fuel rail. (Item 1 is the FRP sensor). I believe on the 2.4ltr Puma these sensors were replaceable but from what I am reading I do not think so on the 2.2ltr. My 10th Land Rover, but my first Defender. |
7th Jun 2016 11:12pm |
The Fox Member Since: 24 Mar 2014 Location: Shrewsbury Posts: 93 |
Sorry to resurrect an old thread - but this sounds exactly like the experience I'm having in my 2.2:
> constant throttle input from pedal (proven using live-data reader) > Anywhere in the rev range > Surging/blipping power loss > EGR actuating as expected > Fuel Rail Pressure sensor showing 'negative-blip' in rail pressure I'd not considered the rail-pressure-sensor to be a possibility. I was looking to replace (in order of cost): VCV Lifter Pump in Tank EGR (unlikely to be the source of the issue) HP Injector Pump Did you solve the issue in the end?[/list] |
5th May 2020 2:28pm |
dannyragsdale Member Since: 07 Oct 2022 Location: Eastern Highlands, PNG Posts: 40 |
Resurrecting this one again.
Fox, did you have any luck with a fix? |
30th Nov 2023 6:09am |
