![]() | Home > Puma (Tdci) > Steering stops, |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
They exist on my 2011...
| Swac3 Member Since: 21 Feb 2015 Location: Aberdeen Posts: 363 |
Hmm, it's odd too, as the stop bolts are wound almost all the way out, so much so that there's no threads clearing the lock nut.
If it's by design it's a pretty crap one. I was under the impression that any correctly made up nut/bolt really should be a thread or two through a nut generally. Need to find a my12 drawing I guess. 3 Landrovers |
| Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123
There should be a plate held on by two of the bolts that hold the swivel housing on.
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946
Just hooking on to this thread, can anyone post a photo of what the steering stop should look like on a MY2012?
Thank you James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2787
I've never seen that on a Defender. Series IIIs had that arrangement, a small metal plate for the bolt head to hit. All my Defenders have just had the lock stop bolt set up to bear directly onto the axle/swivel joint flange. Seems to work fine, apart from the RH one on the 90 which sheared off 8 years ago... must get round to fixing that. Of course it could be that all my vehicles have been missing something, but I doubt it. |
| miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1791
I've heard of it on defenders, but my MY1999 just bumps into the axle tube flange as well.
Hmm , Landrover in different build state shocker
Heres a pic (very poor) of my 1999 TD5, bit blurry but you can see the plate. Click image to enlarge 3 Landrovers |
