Home > Maintenance & Modifications > Painting galv crossmember
excossack
Time has come to paint the galv rear x-member. Can I just use standard etch primer followed by a top coat of satin black or am i going to need a special primer? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #537653 5th Jun 2016 10:34am
Retroanaconda
If it's new galv then you'll need to apply T-Wash (mordant solution), then etch primer then topcoat.
If the galv has been weathered for a year or two then you can generally skip the first step.
Post #537658 5th Jun 2016 10:40am
chasthechippie
Just out of interest for anyone hand painting Dulux do a product called METALSHIELD Quick Dry Primer which is specifically for 'new bright or weathered galvanized surfaces' will also do non-ferrous metals. Not cheap at £100+ per 5l but can save a lot of messing with mordant. We have used it extensively and so far has done the job.
Post #537675 5th Jun 2016 12:07pm
excossack
The x-member has been fitted for around 3-4 months.
I shall take a look at T-wash/Mordant solution 1999 Defender TD5 110
Regards
John M0VAZ
Post #537784 5th Jun 2016 8:18pm
excossack
Just ordered 1L of T-Wash, so hopefully next weekend all being well the x-member will get a coating. 1999 Defender TD5 110
Regards
John M0VAZ
Post #540900 16th Jun 2016 10:18pm
miker
So as of this weekend, my rear door will have a new galv skin on it. I guess the same logic applies? In which case it will stay unpainted for now!!!
Post #540901 16th Jun 2016 10:23pm
If you use mordant solution, just make sure you wear skin and eye protection! It's nasty stuff, ventilation is also a good idea.
Here's my chassis before and after.... Brush it on liberally and leave it for half hour-to an hour, then wash it off thoroughly.
Post #540915 16th Jun 2016 10:48pm
Scott_Landy
United Kingdom 1993 Defender 110 200 Tdi CSW Firenze Red
I was getting mordant solution yesterday (Jihnsons decorating centre). A few places had non in stock but learned from one that ICI were actually out if stock of it!
Post #541194 18th Jun 2016 8:11am
