![]() | Home > Maintenance & Modifications > Whats the best rear bike carrier for 110 CSW |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
This works well with a Mantec as you can open the door
http://www.defender2.net/forum/post230971....88e#230971 Also seen here https://vimeo.com/135047266 |
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 ![]() ![]() |
thanks good call. Is it removable? Does it feel solid when loaded with the bikes? Also would it block the rear lights from what you remember? Thanks, now to check out the price!
P.S like your vid. Wales and North Yorkshire, my two favourite places! |
Yes it's very solid, although I would have preferred a closer fit between the bracket and the rack, there is a touch of play but it doesn't really matter.
Yes it's removable, very quick to slide on / off just a padlock to undo and it comes off. The mount goes behind the spare wheel and onto the Swing away. The bracket pokes through the centre of the spare wheel. It does block the lights and plate, you need a board, I mount mine on the roof rack From memory they are £60, they are for a Disco 1 you have to turn the mount upside down for a defender which means you then need to drill an 8mm hole in the mount to make it work but very easy to do. Last edited by Tiger on 5th Jun 2016 10:33am. Edited 1 time in total |
Does it have to be the Disco 1 or 2 version? What do you secure the bikes with once they are on? Assume some kind of strap set up.
Disco1 version as it has the same PCD as a Defender Disco2 won't fit
You need some straps they don't come with it (not bungees) |
