![]() | Home > Technical > Large crossmember bolts |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 338 ![]() ![]() ![]() |
M10x110mm - part no. AYG100250
what do they bolt on crossmenber on a 90
don't bother seat belt bar parts ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17852 ![]() ![]() ![]() |
Rear seat belt anchor bracket.
Defcon1 Member Since: 18 May 2016 Location: Dorset Posts: 7 ![]() ![]() ![]() |
Thank you for the replies.
![]() No wonder my friends could not identify them, they don't have seats. |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
Can you use these to bolt rear corner protection bumperettes to the rear cross member?
mcgiver Member Since: 12 Sep 2015 Location: brisbane Posts: 23 ![]() ![]() |
just fitted masai swingaway carrier to crossmember at this position..to prevent panel damage spacer needed to be fitted between x- member and lower pivot of carrier which meant the new 110mm bolt was too short. you may find the same problem if fitting step/bumperette ...120/130mm bolt will solve this with the final 40mm or so threaded .....hope this helps..
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
careful....if its too long you wont be able to fit the bolt into some of the bumpettes such as ths safari ones as the rear face prevents placing the bolt.
ahh... didn't see that problem...also noticed my rear panel sits out a little more than on the blue defender pictured....the big hammer must have been misplaced when mine was built....
