![]() | Home > Maintenance & Modifications > Weak rear door hinges |
| Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5895
As per the post, I think it is recgonised that Defs have weak rear door hinges when the rear wheel is mounted. As per another thread, and with a view to using a spare wheel mounted ski rack, I have been c0nsidering a Mantec swing away carrier to ease the burden. However for the same money, yet a lot easier to fit, I do wonder whether billet aluminum hing replacement might be the way to go. Does anyone have an experience or any thoughts about whether or not they make the door stronger and more stable or merely that they prevent rust and perhaps look better? Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
The hinges are not the weakest point, it is the door frame it self that is the problem. All the weight from a heavy spare wheel is hanging from a weak door frame. It will crack, it is not the question wether it will but when it will crack...
So best advise is get a spare wheel carier - especially if you want to hang other stuff like skis or bikes on the wheel (carrier).... Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Thanks for letting me know, I'd didn't realize that was the issue. I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
^ Well, if you see how the original spare wheel carrier is attached to the door frame, you'll get the point...
Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
| mcgiver Member Since: 12 Sep 2015 Location: brisbane Posts: 23
best investment for the rear of your def is a swingaway carrier bolted to chassis member and using original door fixing points to pivot your wheel but not take any loading....just fitted one to my 2010 def 90 which had the spare on the roofrack when I bought it...now have rack I can use and a sturdy spare wheel to stand on to load up...added plus is the door now stays open on sloping ground instead of chopping my legs off...win win.....
| Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000
Has anyone had issues with their swing away wheel carrier lining up properly with the hinges on their door ?
Mine pulls up when it's opened - stretching the hinges open upwards against their internal Spring. Not sure what I can do about it? Last edited by Anderzander on 4th Jun 2016 4:55pm. Edited 1 time in total |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
To be fair in my experience it's more of an issue on the older welded steel frame and aluminium clad doors. The later pressed steel doors are somewhat stiffer and more rigid. Trouble comes when badly adjusted doors with spare wheels mounted on them are allowed to rattle about while in motion plus those gorilla types who insist on repeatedly and aggressively slamming the door shut. Steve. Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| All times are GMT |
