Home > Technical > Momo steering wheel
steverobb1973
2008 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Momo steering wheel
Hi, is there any aftermarket steering wheel, momo or the like that do a 15" size. The standard momo 14" that I have in mine makes it impossible to see the whole dashboard
Thanks
Post #535369 28th May 2016 12:55pm
Wheel
Hi Steve,
I have the same issue sometimes as I guess I must vary my seating position occasionally and it means I can't see the revs below about 3000rpm (unless I lean to the right a bit) which doesn't matter too much as i generally judge where the revs are and the speedo is viewable until about 90 (which I will admit it's touched a couple of times) but again that really makes no odds as most of the time its trundling along at about 55 - 60 ish max.
It was most noticeable when I fitted the new wheel and I looked into a larger dia but I don't think I found a Momo out there but i've got used to it now and hadn't thought of it until seeing your post.
Momo's main importers Brown + Geeson are based near me in Wickford.
Give them a call on 01268 764411 as it may save searching and speak to Dan Brown as he's a good bloke and helpful when I was sorting min.
Mark
Post #535994 30th May 2016 10:06pm
steverobb1973
thanks Ill give them a call.
Steve
Post #536173 31st May 2016 4:35pm
gilarion
As far as I am aware Momo do not do a 15 inch steering wheel, However, Moto-Lita and Mountney do, try having a look on Demon Tweeks web site.
Also and this is from one of this sites sponsors OPIE oils do a range of 15inch steering wheels very reasonably priced… You would have to buy a boss to fit but there are plenty of those on eBay or alternatively OPIE Oils sell corresponding mountney boss kits
Steering Wheels
http://www.opieoils.co.uk/search/go?p=Q&am...;view=grid
Bosses
http://www.opieoils.co.uk/p-89864-traditio...ntney.aspx For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #536191 31st May 2016 5:02pm
Doubledoom
United Kingdom 2016 Defender 90 Puma 2.2 SW Santorini Black
I know it isnt exactly what you asked but I have the startech and the dashboard vision is fine. However, I guess like all of these things, it will depend on your seating position,what type of chair, height etc. Adjustments: Startech Steering Wheel | MUD Interior LED lights | Wipac crystal headlights with osram nightbreaker bulbs | Alpine CDE195BT
To do list: Outside rear facing LED lighting | subwoofer and speakers
Post #536329 31st May 2016 10:36pm
steverobb1973
Thanks for all your posts. I have now went for a Startech
Steve
Post #537510 4th Jun 2016 5:59pm
gilarion
Good choice Thumbs Up For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #537521 4th Jun 2016 6:13pm
Screbble
Interesting thread/post, as I have been considering a 350mm Momo and hadn't thought that it may obscure the dash a little.
Has anyone out there fitted a Momo 350mm with an Optimill (slimline) boss? If so, what is it like to live with - both in terms of viewing the clocks and proximity to the column stalks.
Cheers,
Will
Post #582950 5th Dec 2016 10:14pm
Vintagepaul
2015 Defender 90 Puma 2.2 HT Santorini Black
I have a 350mm Momo fitted and have no problem seeing the dials or a problem using the stalks.
It's fitted onto a FCX quick release boss which I think is smaller than the standard Land Rover boss.
I'm really pleased with the wheel which is a huge improvement on the standard one. Thumbs Up
(Sorry about the blurry pictures, their the only ones i've got at the moment) 2015 Defender 90XS HT
Post #583188 7th Dec 2016 8:15am
Screbble
Thanks for sharing the info and photos Paul Thumbs Up
Which Momo is that? It looks nice.
I guess the issue relating to visibility depends on a number of factors including driver height, seat position etc.
In terms of the boss, it does look slimmer than the std Momo.
I wouldn't mind seeing some photos from owners with a 350mm Momo with the Td5 dash Thumbs Up
Post #583356 7th Dec 2016 10:48pm
Vintagepaul
It's a Momo Jet. Thumbs Up
http://www.momo-uk.co.uk/Momo-tuning-jet-s...ck-leather 2015 Defender 90XS HT
Post #583399 8th Dec 2016 5:59am
