Calling Switch Connector
Ciao,
How do I get the connectors back out of the block;
I have used the wrong colour wire and need to remove the little pins from the block. I can see the little tab I need to press down to withdraw the pin but I can't seem to get it out to save my life.
Yan
29th May 2016 10:48am
Alien
A jeweller's narrow flat screw driver may do the job.
I've used an open split pin in the past with a little bit of grinding/filling to suit the width, squaring the end is important too.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
