![]() | Home > Technical > Nominal drop arm angle with respect to vehicle forward? |
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2787
It should be slightly off straight when the wheels are dead ahead.
Don't go looking for problems that aren't there, if it drives ok don't worry about it. |
| agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324
Thanks, off centre in which direction?
Since it's going to be pulled apart anyway, i may as well get it right. It's the engineer in me - I get more buzz out of fixing it than driving it... (Horses for courses) Solved the bowel problem, working on the consonants... |
| Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674
There are two drop arms one for L/H and one for R/H if the incorrect one was fitted the turn ratios would be out to the point you could not drive it. It has confused many people in the past why after fitting a drop arm that was on the shelf rather than using the old one after fitting a new box means the steering is out, one bloke swapped the box twice, all steering tie rods, the damper, power steering pump and wanted to swap the front axle as he had run out of ideas
Not sure which direction.
There's a slot in the back of the arm that is supposed to line up with a hole on the bottom of the steering box at the dead ahead position. At least there is on 4-bolt boxes. |
| All times are GMT |
