Home > Td5 > [HELP] Easy access to permanent live on 2000 TD5 90 |
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 |
depends where you are going to put the tracker I suppose. You can run a wire from the battery to any location. Try and hide it. I assume the ignition has perm 12v for dash installation. starter motor/alternator. Not sure there is anything in the rear
25th May 2016 7:06pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1759 |
Purple wire in the load area on the rear light loom is perm live. Drivers seat box has supplies. Passenger seatbox has the battery! Engine bay - starter.
Dash: Radio has a permy feed. Interior lights too. That should give you a bit to go on! |
25th May 2016 8:29pm |
jrharte Member Since: 08 May 2016 Location: Newry Posts: 20 |
Thanks guys.
So I guess from these pictures that the purple is perm live and the red going into the orange plug is only live when ignition is on? Click image to enlarge Click image to enlarge Click image to enlarge |
27th May 2016 7:02pm |
Yep permanent 12v as confirmed here by Martin also: http://www.defender2.net/forum/post533333.html
Thanks Miker. I also found this: http://www.dimebank.com/LucasColours.html If it's of use to anyone. |
27th May 2016 7:25pm |
