![]() | Home > Puma (Tdci) > Whine from rear end |
IS the noise the same when the vehicle is both under load and on overrun and have you tried knocking it into neutral when you are going along so that it's just coasting and seeing if it still whines then?
I'd check the easy things first like fluid levels, Check the prop uj's & lubricate, check the transmission brake isn't binding, wheel bearings etc. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
I know the wheel bearing are fine , Diff oil checked 3 weeks ago, same sound both under load and on over run.
I can still remember the last time I free wheeled a vehicle, 1970 , Chimney Bank, Rosedale , change of undergarments for all occupants, non servo and only shoes for brakes which got hot and faded. I'll give it try on more level ground. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 ![]() ![]() ![]() |
Sounds strange (IMHO) for it to sound the same both under load and on over-run. Did you inspect the oil when you dropped it? For the cost of it I'd drop the oil again and look for debris / particles.
Rear diff' certainly isn't a difficult thing to change so you could save plenty of ���s by DIY ![]() |
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 ![]() ![]() |
could it be coming from your exhaust??? I'm sure my exhaust has a midl whining noise coming from it and have always wondered if that is normal!
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
If you want to determine if its the front or rear diff, put the car in diff lock, then remove the front propshaft and go for a drive. Then replace the front and remove the rear propshaft. If the noise is there when only one of the propshafts is removed then you know that the diff which is still connected is the problem. If its there during both then look elsewhere. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 306 ![]() ![]() ![]() |
Had the same issue last week (8000miles) with mine, the dealer was convinced it was the wheel bearing protesting but ended up changing the half shafts and the bearing.
All fixed. |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3838 ![]() ![]() |
If its the Diffs
Is that a big / expensive job to change? |
Rear diff' is expensive but not a huge job (just because of LR parts costs) - front diff' is a little more involved. Personally, unless it was done under warranty I wouldn't consider LR parts - I'd go straight to Ashcrofts
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Sorry arc but mine whines from both ends..she only really stops when her mouths full!
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 ![]() ![]() ![]() |
By any chance is the mother in law in the back? Cheers Don.
Sorry folks I have not been ignoring the replies just to busy.
I know its the back as my ears tell me so. I have checked with both of them. Its still there when the wife gets out. The mother in law died some 20 years ago so it cannot be her. The diff oil was nearly as clean as it was when I put it in 6 months ago. The only other time I have heard such a noise was from an army truck tyres. I may swap front and rear tyres to see if the noise then comes from the front. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 ![]() ![]() |
I had a strange whining noise which was very hard to pick where from on my 2010 110 a couple of years back. Sounded a bit like bag pipes .... which I like generally but not from under the vehicle.
![]() I picked rear diff, cook reckoned engine and someone else said gearbox. Took it back to the stealers for a check while other warranty stuff was being fixed and they said transfer box. That was at 98K kilometres. At that mileage (kilometerage?) they would normally have changed it for a recon box but as none were available in Oz they put a new one in. Noise gone and I was happy vegemite...... for a while. ![]() AlanH. |
Well I tried the free wheel and the noise is still there. The noise is only noticeable above 15 M.P.H. and it dose not matter what gear it is in. Its got me beat so its off to an Independent next week to see if they can locate the source. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Well just an update............Been to have the 110 looked at, not repair yet. It appears that the noise is coming from the rear diff and the conclusion is that it is the pinion bearing (the bearing on the input side). Don't make old people mad.
