![]() | Home > Technical > 52mm wheel nut socket maximum outside diameter? |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 ![]() ![]() |
While this will not answer your question I'll through this out there for consideration after going through the same dilemma recently.
Why not buy the 1/2 drive socket as I did. I carry a full 1/2 drive socket set and a pipe to fit over the breaker bar, I don't carry 3/4 drive gear due to weight. I've converted from the one use nut to the 2 nut and locking tab set up. I've retained the spacer and do the first nut up as tight as I can, lock tab on and do the outer nut to secure it all. This allows me to carry the socket only to match my tools and I can do a wheel bearing on the side of a track/road if needed, I carry a spare set. With this set up once I removed the 4 staked nuts the stresses on the socket (and required drive size) are greatly reduced. Just a different way of looking at things I guess. Cheers, Kyle. |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
I didn't know the two systems were interchangeable - in fact, I didn't know there were two systems
![]() But thinking about it now, ok, as long as there is enough thread and space then yeah what is good for the goose is good for the gander. In the meantime I've decided to just go for it with the3/4" and a sliding bar is on its way with a 3/4">1/2" reducer so I can make the most of the 1/2" socket sets I've got. (6 and 12 point). So the 1/2" 52mm is probably the way I'll go. Going to set up a CNC mill and machinists hovel at the farm one day, tractoring going on also - the 3/4" bar might come in handy... Solved the bowel problem, working on the consonants... Last edited by agentmulder on 24th May 2016 8:13am. Edited 1 time in total |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
I carry a box spanner which has a 3/4 female receptacle incorporate in the non-hex end, Melco I believe, with a 3/4m to 1/2f adaptor so it c an be used with 1/2" socketry. It is much lighter than a 3/4" socket, and is quite strong enough for either two-nut or single-nut systems.
I use the 1/2" drive generic 52mm impact socket with no trouble at all, there is little difference in the o/d of the two drives, it's just the size of the hole where the bar goes in.
Even at a 10mm wall on the socket it'll still fit . |
Exactly the info I was after. Cheers. Solved the bowel problem, working on the consonants... |
