Home > My Defender > Here come the mods....!
Page 10 of 18 <123 ... 91011 ... 161718>
RRUK
All's well that ends well Laurence, soon be looking lovely. Thumbs Up 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #532830 18th May 2016 11:15pm
Butchers Boy
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
So finished lining the inside of the roof today, really please I've done it
My top tip when doing this is when peeling the backing off hold on to the insulation with a piece of scrap paper that you have already removed because this stuff is really sticky. Once stuck to your hand and fingers you'll tare the backing off trying to remove it!
Dose anybody know what a number on a piece of paper is for found stuck to my roof above the drivers seat??
The new headling should be here tomorrow ready to go in at the weekend Mr. Green :mrgreen:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2010 Defender 90 HT
The longer I live..... The better I was!
Post #533083 19th May 2016 10:26pm
RRUK
Laurence, did you purchase any extra long fir trees as per my thread?
The new headlining is much thicker and the original ones are too short for the cross centre fixings on the overlap between front and rear sections. This is especially true now you've put the thick sound proofing in.
Also, it's worth drilling out the rear centre rib hole and putting one there to prevent sagging. 2016 D4 HSE
Post #533237 20th May 2016 6:57pm
Butchers Boy
Adam,
Yes I got the same ex long F'Tree's as you did in black and I was going to drill some holes for extra fixings along the center to stop the sagging as well - great minds mate Thumbs Up
I have a large box in the back of my van Mr. Green It arrived this afternoon at work (I took the van in today in anticipation Thumbs Up ) I suspect its from those nice chaps at oemlandrover and contains my new headlining!! I haven't had a chance to get it out yet but I'm heading that way very shortly to retrieve it out the van and in to my dinning room... its like Christmas Cool !!
I'll post some pictures shortly...... 2010 Defender 90 HT
Post #533244 20th May 2016 7:10pm
Butchers Boy
Looking good for fitting tomorrow!! I'm going to leave it all in the plastic for tonight it looks and smells great!!
Everything arrived packed really well in a sturdy box with both roof linings wrapped in thick plastic bags keeping it all in first class condition on it journey from oemlandrover to me Thumbs Up
Post #533270 20th May 2016 8:38pm
RRUK
I had to spray my sun visors, lucky you! 2016 D4 HSE
Post #533288 20th May 2016 9:56pm
Butchers Boy
So up early this mornig ready to make a start on fitting the new head lining. Thumbs Up
First job is to put new rivnuts in the rear view mirror housing. When I removed the housing to remove the old headlining all three of the original rivnuts came lose and spun round as I tried to unscrewed the housing making removal difficult - but not impossible! So new rivnuts are needed to screw secure the housing back in
This is the mirror housing
This isn't a hard or expensive job I purchased a rivnut tool for less than £12 and a selection of 100 rivnuts for £5 (the box wasn't included!)
It took me less then 10min to complete the job of fitting new rivnuts in to the housing
Once that was done I unpacked the new headlining... WOW!! Very impressed with this! Great quality product it feels, looks and smells every bit quality... it is an original LR product (from oemlandrover) and has the LR sticker on the back to prove it Thumbs Up
I offered it up to the roof I had to flex it and bend it a bit to get it exactly where I wanted it. Don't be afraid of doing this it's very strong and soon springs back in to shape. I did it on my own holding it up with one hand and putting the new fir tree's in with the other to hold it in place it would be easier with two people but it's not too difficult on your own. The advantage of using an original LR part like this is that all the pre-drilled holes in the new LR headlining lined up exactly with the holes in the roof so it was easy to know exactly when it was in the right place and the fir tree's just pushed in without having to fiddle about trying to locate the hole the other side of the headlining too much Thumbs Up Top Tip: Don't fit all the fir tree's above the front seats there are two holes that need to be left free for fir tree's that fit through the rear section and front section when they overlap later.
With the front section in place I couldn't help fitting the new SVX black sun visors that I purchased with the headlining! I wasn't sure I'd made the right choice to start with but these are really nice quality and look great a really good choice if I may say so myself Whistle Laughing !!
In the backdoor with the rear section of roof and again much bending and flexing to be had here just to get it through and in to the rear of the vehicle. Once it's in I found it quite easy to fit. The trick here is to make sure you get it above the extended sections that hold the rear 'telephone' panel on above the rear door first then offer one side up and flex the other side up and again much flexing etc to be done to get it in to place but don't worry its very strong. There are only two fir tree's to be pushed in on the rear section they are located where it overlaps with the front section. There are pre-drilled holes but not in the fabric so you have to feel along the edge for the holes I just used a knife to put a little hole through the fabric so I could push the fir tree through once I found the holes. They line up with the holes of the front panel and the pre-drilled holes in the metal roof exactly.
I run out of time I still have the interior lights to fit and a few other bits to tidy up but I have to say it looks amazing it not only gives a real quality feel to the inside but IMHO it also makes it feel sporty and a much nicer place to be Thumbs Up
My next mod will be new seats and new cubby box....... Any recommendations on seats ...??
Post #533578 21st May 2016 11:16pm
RRUK
Looking very nice Laurence, doing this on mine was one of the most satisfying improvements, the alcantara feels and looks so good.
Re the seats, I'd go for the Land Rover premium one piece back style, and a high top padded cubby box. You often see on eBay people selling them as a package straight out of the newest ones, and the black and pimento red combo looks nice. 2016 D4 HSE
Post #533666 22nd May 2016 11:13am
Butchers Boy
Hi Adam,
Great minds mate! I just spotted these Premium Front Sports Seat TDCI Puma Defender Original LR Red/Black Thumbs Up
http://www.oemlandrover.co.uk/store/p138/P..._Defender.
Post #533682 22nd May 2016 1:25pm
Butchers Boy
Hi Adam,
Post #533683 22nd May 2016 1:25pm
RRUK
Comfier than corbeau ones! 2016 D4 HSE
Post #533848 22nd May 2016 10:14pm
RRUK
Seen this?
http://www.ebay.co.uk/itm/Land-Rover-Defen...Sw3d1TzWfy 2016 D4 HSE
Post #533853 22nd May 2016 10:19pm
Butchers Boy
Adam,
They are quite something mate Shocked !!
Not sure if I'd be brave enough to put them in tho...??? Prefer to go with the omelandrover seats as they are original LandRover items. Very tempted with ome seats pictured above in red and black.... But also like the black with white stitching sports seats...... No I'm going for the red & black... although black with white stitching... Confused Confused Laughing
Think I'm going to have to give it some more thought.....!!!
Come on chaps help me out here... Has anybody got pitures of the red/black sports seats in their Defender??? 2010 Defender 90 HT
Post #534057 23rd May 2016 7:09pm
TACK
Laurence, looking good, mine arrives Wednesday from OEM so I will post my pics up once it's all done. Found OEM great yo deal with Thumbs Up so that's for the recommendation.
Spoke to Phil and they do an original premium seat retrim kit. I did my at the weekend (5hrs 2 seats) using a exmoor product. OME do a genuine LR premium seat retrim kit for about £30 more but they have done half the work for you compared to the exmoor one. Worth speaking to Phil on. Could help you do it. Reckon I could do 2 exmoor kits in half the time now I know how to do it. Mr. Green
Post #534103 23rd May 2016 9:10pm
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
They would suit OHs new Twisted 90. Thumbs Up
Post #534105 23rd May 2016 9:16pm
