Home > Puma (Tdci) > 110 Suspension
Page 1 of 3 123>
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
110 Suspension
Hi,
Me and my Dad have been noticed that the front bumper on our 110 Puma has been riding lower than normal for quite a while now. This is probably because it has a Warn 9.5ti winch and a aftermaket bumper on it. I am a aware that Land Rover do a heavy duty suspension kit for the defender but I was wondering if this fits on the standard chassis?
Thanks Jack
Post #53381 16th Jan 2011 11:39pm
Lorryman100
I was looking to get the HD springs from Landrover but decided on Old Man emu OME751 front and ome 755's on the rear from devon 4x4. A few guys on here have these fitted with no problems with prop clearance etc. and they have winches, roof racks etc.
You can get them HERE
The Landrover HD coils for a 110 are:
FRONT COILS
PART No. POS. COLOUR CODE.
NRC 9448 F/O/S BLUE/RED
NRC 9449 F/N/S YELLOW/WHITE
REAR COILS
NRC 6904 R/N/S RED/GREEN
NRC 6389 R/O/S RED/RED
Post #53386 17th Jan 2011 12:01am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
I have the same problem on my 110DC ... I recently bought the Land Rover front HD ones ... Hoping to solve my problem ... A friend replaced on his 110DC and his truck has improved a lot! It's leveled!
Was going to fit them this last week, but got the A flu!
Will post pics when I fit them ... at the end of next week ... Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #53388 17th Jan 2011 12:37am
AndrewS
Whatever you do to the front do the same at the rear. Especially if you are going to carry a fair bit of kit.
If you leave the rear standard it will sit on its ass when loaded.
110 HD front standard rear
130 OME +50mm on the front standard rear
 130's have feeling's as well you know Smile
Post #53397 17th Jan 2011 8:50am
jst
are 90 HD rears the same as 110 HD fronts? thats an option i have used in the past to level a 110. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #53401 17th Jan 2011 10:17am
MK
Í`m not sure if pre-2007 spring coils are effective on Pumas. This vehicle has a different suspensión-driveline geometry and may not accept any lift. So some of the new HD springs have a different spare number compared to the lastest Td5 etc. I might be wrong. Puma 110" SW
Post #53402 17th Jan 2011 10:47am
Landie Boy
Thanks for the imput guys Smile
Do you know if the shocks would need to be changed as well?
AndrewS what is the colour of that 130? it works really well with the car Smile
Thanks Jack
Post #53405 17th Jan 2011 10:57am
TallPaul
Thanks Jack
I think you'll find its from a LR paint pot but not the Defender brochure! Andrew has a thread somewhere on his 130 build in "my defender" subforum, details are in there as I recall...
(Balti Blue sounds familiar?) Disco 3 gone but the memory of the bills remain...
XS 110 Utility maybe one day..... (did they fix the quality yet?)
Post #53413 17th Jan 2011 11:51am
nakatanenga
Germany
Caution!
Puma drivetrain is about 180kg lighter than Td5 drivetrain.
So HD Springs out of a Td5 have a different effect in a Puma Wink WANTED:
SII or SIII in max 1.5k
Post #53416 17th Jan 2011 12:12pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Last year I was thinking of putting HD LR springs on my 110 after taking advice on here and when I spoke to the dealers about fitting them they sniggered and told me mine being an XS was already fitted with them and that the only up grade was 130 rears. Was/is this correct?
Post #53423 17th Jan 2011 1:51pm
MK
110&130 rears do not fit in front as they are of different diametre. Puma 110" SW
Post #53425 17th Jan 2011 1:57pm
The Boy
Sorry perhaps I was unclear. I meant they said I could only uprate the rears and that would be with 130 rated springs and my fronts were already HD ones.
Boy
Post #53428 17th Jan 2011 2:08pm
MK
From MCat for 110"&130"
1-RKB500300: WHite/green/green
2-RKB101111: brown/purple, Station Wagon, 5 door with 5 seat configuration
3-RRC3266: coil helper, HD suspension.
However, from what have seen 130" come with 2+3. Not sure how a 110" would go with 2 or 1+3. Puma 110" SW
Post #53430 17th Jan 2011 2:20pm
The Boy
I don't want to lift it much just to give a little more room for the 285's and to level the front up a bit. As soon as I have some spare cash I was going to the OME as recommended earleir in the thread. I don't have a winch but i do have a HD bumper that seems very heavy compared to the one it replaced. I did have OME springs and shocks on a 110 years ago and it really did transform the ride.
Post #53431 17th Jan 2011 2:32pm
Lorryman100
Defender 110 and 130 rear coils have a nominal outside diameter of 7" compared to 6" on the front
NRC9462 90HD R/D/S Length= 15.25inches, lb/inch= 210/240, coils= 9.2, with colour code green/yellow/red
NRC9448 110HD F/D/S Length= 15.31 inches, lb/inch= 225, coils= 8, with colour code blue/red.
Not much in it size wise James, a good shout if you have the 90hd rear coils lying around or want that extra bit of stiffness and loading Thumbs Up
RKB101111, D110 (VIN XZ159807 up), Rear, Length= 16.10, lb/inch= 270/420, coils= 8.8 with colour code brown/purple are standard rear coils.
NRC6904, 110 HD, R/N/S, Length= 15.55 inches, lb/inch= 330, coils= 8 with colour code red/green
NRC6389, 110 HD R/O/S, Length= 16.02 inches, lb/inch= 330, coils=8 with colour code red/red
These are the HD springs for the 110. The drivers side will always be that bit stiffer to compensate for the weight of the driver so the landy sits level when driving.
HTH Brian.
Post #53433 17th Jan 2011 2:35pm
Page 1 of 3 123>
