Home > Td5 > Defender Td5 header rail from all wheel trim
chinnus
2001 Defender 90 Td5 ST Coniston Green
Dear all,
Fitting the soft top to the land rover and everything has gone ok apart from the header rail. I cannot see to work out how it goes or if i am doing anything wrong....
Please see the attached pictures for refrence..
Does the header rail go over or under the side drain channels?
Does the header rail go flush to the windscreen glass or over it
Post #533706 22nd May 2016 3:12pm
dorsetsmith
Post #533718 22nd May 2016 4:05pm
chinnus
thank you for that... I am not sure if the header rail is in the correct position or if its the right one? But surely allwheel would have supplied the correct one?
Tom
Post #533721 22nd May 2016 4:17pm
dorsetsmith
1
Post #533723 22nd May 2016 4:24pm
chinnus
thank you for the reponses...
So the header rail goes over the top of the side drain channels...
I may need to move them backwards but there isnt a huge amount of room?>
Tom
Post #533727 22nd May 2016 4:27pm
chinnus
I have drilled this bolt here which is as far back as I can get the header rail but then the clamps wont sit straight in the cab... do i need to try and shift the whole lot backwards?
Post #533730 22nd May 2016 4:35pm
dorsetsmith
the red arrow and rope edge will need to fit in round channel orange arrow and yellow arrow weather strip to keep out ran
Post #533735 22nd May 2016 4:47pm
chinnus
thank you dorsetsmith. I get that rope edge of the canvas goes into the big u shape
its the drilling and physical placement of the header rail to attach it to the windscreen... I cannot seem place it far enough back to drill the thin part of the windscreen to allow the brackets and springs to be used?
Do i need to shift the hole hoop set and drain channels back?
TOm
Post #533738 22nd May 2016 4:55pm
dorsetsmith
do the hole in your header not line up with roof fixing hole ?
Post #533743 22nd May 2016 5:06pm
chinnus
no they dont line up at all. Completely different locations on the windscreen to the header rail. So I have to drill 4 more.
Does the header rail have to mount further back so that i drill on the flat bit of the windscreen, highlighted here in red
Post #533744 22nd May 2016 5:13pm
dorsetsmith
drain channels position is fix by the holes that the top windscreen
Post #533746 22nd May 2016 5:25pm
chinnus
Its almost as though the part circled in red is too long which is stopping the header rail moving backwards to fit in the correct location
Where the header rail currently sits and where i could drill the holes it sits over this part highlighted in red. Which is too long for the bolts to go through for the clamp...
Should the header rail be bolted through the green highlighted areas??
Thank you dorset for your patience!!
Post #533750 22nd May 2016 5:51pm
dorsetsmith
or the header rail ends need to be cut to fit side drain channels both side. if you look at the pic from in side the cab the side drain channel are featherback, but looking at your pic of your drain channel fix in place you do not have that much to work with and they look right to drain rain down the screen
phone call all wheel trim ?
Post #533755 22nd May 2016 6:14pm
Mdm
if you mean the windscreen frame with the extra holes then yes this is common depending on the age of the landrover.
i have just done this to one i have converted as well
Post #533777 22nd May 2016 7:24pm
chinnus
So .. I unbolted the drain channels and put the header rail where it should be, drilled the holes and then with some jiggery pokery managed to slowly screw the drain channels into place and they bent a little bit into shape!
Thank you all for your advice on this subject!
Post #533822 22nd May 2016 9:17pm
