Home > Maintenance & Modifications > LED light sets
Ridgeback defender
LED light sets
Looking to purchase LED lights for a 2010, 90 H/T. What do you recommend ?
Post #533526 21st May 2016 9:25pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
Rdx led side, brake, fog, reverse and indicator lights.
Side indicators from 4x4 overlander
For additional lights aurora 40" light bar for the roof, durite 6" slim fog and winch 4" rear work light and 9" arb intensity copies
Some would say i have a light fettish Rolling with laughter 2004 TD5 Defender 90 xs station wagon
Post #533538 21st May 2016 9:42pm
"Rdx led side, brake, fog, reverse and indicator lights.
Side indicators from 4x4 overlander "
Exactly the same as me. Thumbs Up
Post #533549 21st May 2016 10:06pm
johnszs
I forgot wipac number plate light too 2004 TD5 Defender 90 xs station wagon
Post #533554 21st May 2016 10:13pm
Martin
Site Admin
95mm NAS/SVX type. 2 and a quarter times the lit area of the standard (tiny) lamp Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #533556 21st May 2016 10:16pm
L110CDL
Me to as Johnszs Thumbs Up Clayton.
Keeper.
Post #533562 21st May 2016 10:27pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
NAS lights with LED bulbs. MUCH better than any LED offering from any manufacturer Thumbs Up
Post #533571 21st May 2016 10:52pm
Cheshire110
What do people do about LED indicators?
I can't afford to lose trailer light indicator or any faffing around if I attach a trailer.
Do the aftermarket relays handle it well? Cheers, David
Post #533579 21st May 2016 11:20pm
Yes, they are adjustable.
Only issue you'd have is with LED lit trailers.
If that was the case you'd need resistors the trailer OR a buzzer instead.
My trailer is incandescent lit so keep the light with my RDX kit.
I may go LED on my trailer one day but that would be an annoyance.
It'd work, no problem but the legality of light or buzzer would not be there, which is very annoying!
Post #533582 21st May 2016 11:27pm
Cheshire110
Yeah that seems to be my understanding.. However RDX advertise a relay which can supposedly deal with trailers and also a mixture of LED/bulb lights on the car.
Very tempting.
It's included in this kit which seems good value:
https://www.ebay.co.uk/itm/390534410803 Cheers, David
Post #533586 21st May 2016 11:35pm
That is good value, I spent a lot more than that for the same set.
Don't get my wrong physically the lighting on vehicle abd trailer will work perfectly regardless of LED's or incandescent standard bulbs.
The relay also allows you to adjust the dash trailer light too.
The one and only issue is if you have an LED lit trailer the dash trailer light then won't work.
The trailer lights will fine but with no indicator warning buzzer or dash trailer light on when towing is illegal.
It's not an issue to me as my trailer is incandescent lit as standard.
There's no real workaround to keep the dash light around this on if yiu had an LED lit trailer other than resistors on the trailer indicators or a buzzer fitted in vehicle instead.
Overall, an excellent solution. Thumbs Up
Post #533594 22nd May 2016 12:51am
CarMan
So, are the Wipac and RDX sets different? Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #539677 12th Jun 2016 7:04pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #539705 12th Jun 2016 8:28pm
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
http://www.bowerspartsonline.co.uk/vehicle...t-rdxwipac
Post #540069 14th Jun 2016 3:01pm
They are slightly different in reflector design and light pattern, however, you'd barely notice.
Post #540072 14th Jun 2016 3:13pm
