Home > In Car Electronics > Clarion NZ502E head-unit and sound system advice please
Lancerdoc999
I have a Clarion NZ502E single DIN flip out headunit which I plan to install into a MUD centre console assuming it will fit.
There was an old LR locked radio previously so not had any audio for 18/12 since bought the Landy.
Can anyone shed any light on how much the screen will angle when out? I would like to fit the unit in the sloped upper part of the console but feel it may hit the dash. This would free up the front for switches.
Can anyone in the know advise on whether I can simply use the connectors from the previous radio or do I need a loom or to modify the connectors?
I have the standard front LR speakers and have some ready to wire up in the rear also but wonder if it better to upgrade these and include anything else like an amp etc.
Looking forward to some kind of sound whatever it is! many thanks for advice.
Post #532841 18th May 2016 11:44pm
Do you already have the HU? If so you could just power it up externally and have a look see.
Monitor angle action is sometimes mentioned in manuals, but I would imagine sometimes not.
You also have to bear in mind the action of it coming out is often a larger distance than what it is in position.
On mine. (Kenwood) it comes out a fair way flat, opens vertical then slides back in and adjusts angle once out.
They do vary, I think the Clarion is likely to take up less room actually.
There should be members on here with the same model that can perhaps advise you?
A 2007 - 2012 Puma should be plug and pay. Post 2012 you need an adapter but is still plug and play.
Ideally speakers and HU should be changed at the same time, but not a requirement.
Post #532846 19th May 2016 12:05am
Lancerdoc999
mines a TD5 so assume that complicates matters! MY00
Post #532848 19th May 2016 1:08am
Likeomg
i have one, theres quite a bit of adjustment in the angle it extends out at, i dont have my car currently but should be picking it up tomorrow afternoon...
Post #532883 19th May 2016 10:02am
Can't get my bearing quite but that looks like the TD5 dash wiring.
If that is the case you have DIN ISO wiring present by the looks of it.
Plug and play with no adapter required. Thumbs Up
Post #532914 19th May 2016 11:54am
Swac3
This is mine but in a Puma dash, not sure if that's any help gauging the angles. It was in when I got the truck so dunno if
theres a better way to have it.
 3 Landrovers
Post #533027 19th May 2016 8:36pm
walfy
How do you get it to angle back like that? Been through the menus but can't find the angle settings. I can also get it pop open on start up but can't find where it puts itself back. Any help? 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #533045 19th May 2016 9:00pm
Swac3
Its always been like that, previous owner installed/had it installed. I do have a manual somewhere tho I'll have a look and see if theres anything in there
Mine doesn't open on turning the ignition on it just plays whatever was selected previously, it does auto open when I select reverse and the rear parking camera comes on, to close it press the button on the left top of the flip up screen marked OPEN.
Nothing at all about opening angles or the adjustment. It basically just says install within 30 degrees of horizontal, and that some cars may present obstuctions to the screen opening and therefore the unit isn't suitable for those cars 3 Landrovers
Post #533047 19th May 2016 9:02pm
Likeomg
if you press and hold the 'open' button, a tilt up/down thing appears and you can adjust the angle...
Post #533053 19th May 2016 9:21pm
Swac3
General setup
TFT Auto Open: There are two options, On and Off. If current setting is On, the TFT screen will slide out automatically when the system is power on. If current setting is Off, the TFT screen will always keep the last position when the system is power on. 3 Landrovers
Post #533055 19th May 2016 9:22pm
Swac3
Likeomg OMG would have thought that would have got a mention in the installation section but I see it now you said that,
[OPEN] Button • Press this button to open/close TFT panel. • Press and hold to enter TFT panel angle setting options. [
every days a school day. 3 Landrovers
Post #533057 19th May 2016 9:26pm
Likeomg
i figured it out by accident... Shocked great head units, love the built in nav... got it 2nd hand with loads of add ons Very Happy
Post #533061 19th May 2016 9:30pm
How much are they new?
Kenwood discontinued 1DIN in their line and pursued the 2DIN route, regardless the cost is very very high.
Pioneer and Clarion seem to be continuing in this market the latter being more popular and highly rated.
It's good to see the screen angle abd slide control.
Is there multiple colour options for display?
Post #533068 19th May 2016 9:53pm
walfy
Will have a play tomorrow. I was hoping that the screen would put itself away when the ign was turned off. Otherwise it means the screen will spend it's life in the open position. I always seem to be in a rush when I get out and don't have time to close it. 110 D250 SE HT
110 USW SOLD
Post #533071 19th May 2016 10:04pm
Lancerdoc999
Thanks swac3. I'm going to need mine to tilt as far forwards as possible as would like to put in the upper angled portion of the mud console if I can.How far forward does it tilt if you don't mind testing for me. Cheers
Post #533117 20th May 2016 7:41am
