Home > Maintenance & Modifications > Rover v8 carb tuning
charcoal
United Kingdom 2005 Defender 110 Td5 HT Bonatti Grey
Does anyone know of a good place to get 3.5 twin su carbs tuned in Hampshire, preferable south east. Mine appear to be unbalanced and when going over about 60 they will struggle to run, I'm no expert on these engines but I'm assuming they'd need balancing anyway? 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold
1995 Land Rover Defender 110 V8 Station Wagon ~ Sold Sad
1985 Land Rover 110 ex mod project Tithonus ~ Sold Sad
Post #532385 17th May 2016 4:16pm
Romadog
There is a place in Salisbury
http://sucarb.co.uk/contacts/
Post #532422 17th May 2016 6:09pm
charcoal
That's a bit far away, I'm right on the Hampshire/Sussex boarder. I'll keep it in mind though, any other suggestions are appreciated Thumbs Up 1999 Land Rover Defender 110 td5 station wagon
Post #532500 17th May 2016 9:31pm
Iggle piggle
United Kingdom 1989 Defender 90 V8 Petrol ST Alpine White
Assuming they are SU carbs?
they are fairly simple to set up with no special tools needed,
loads of videos and websites with all the know how, I enjoy tinkering with mine (carbs that is) Whistle
Post #532518 17th May 2016 10:22pm
charcoal
Yes SU carbs, I have been under the impression you'd need specialist experience to tune or balance them properly. May have a go over the weekend then, what's the worst that could happen Laughing 1999 Land Rover Defender 110 td5 station wagon
Post #532523 17th May 2016 10:34pm
Iggle piggle
Loads of info here & very helpful on the phone
http://sucarb.co.uk
Are you using K&N (or similar)filters?
Post #532541 17th May 2016 11:02pm
charcoal
No, I have the original air filter pipework but it goes into the air box from a normal car, Rover 75 I think? 1999 Land Rover Defender 110 td5 station wagon
Post #532549 17th May 2016 11:37pm
Iggle piggle
I fitted K&N cone filters direct on the the carbs and had a similar problem to you,
I came to the conclusion that they were getting to much air & not enough fuel through them at full throttle when running the standard needles
Runs & performs much better on the standard induction system
Post #532569 18th May 2016 7:32am
charcoal
My problem could be similar but the other way around, the air box fitted is tiny. My standard air box wouldn't fit between the bulkhead and engine. Do you think a RR efi air box would be a suitable replacement? 1999 Land Rover Defender 110 td5 station wagon
Post #532590 18th May 2016 9:41am
Romadog
I had K&Ns on my last V8 with SUs - worked perfectly. You could really hear the carbs suck ! Thumbs Up
There is a book on Tuning SU carbs, which I have somewhere. It explains the process on how to set them up etc.
http://www.ebay.co.uk/itm/SU-HS-H-HD-HIF-H...3641.l6368
Get hold of a carb balancer.
http://www.ebay.co.uk/itm/Carb-Balancer-Ca...cZe5BIvwQw
Post #532729 18th May 2016 8:04pm
charcoal
Many thanks, will look into them both! 1999 Land Rover Defender 110 td5 station wagon
Post #532731 18th May 2016 8:06pm
