![]() | Home > Puma (Tdci) > Another output shaft failure... |
| Fish13 Member Since: 17 May 2015 Location: Aberdeenshire Posts: 71
Thanks Shax,
I'll post pics of mine when it's done. Parts were ordered today, hopefully done tomorrow. This one lasted 41k dry, so hopefully get a lot more out of one that's greased! If it feels anything like it did again, I'll buy the Ashcroft one in advance. Has anyone fitted a properly greased one and what mileage have you gotten out of that? Curious to know! Cheers, Fish. |
| Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006
Hate to say it, but I've found greasing them a waste of time. Unless you can keep greasing it the grease just dries out and becomes a rusty grinding paste on the splines.
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
Raising my head above the parapet...
Would there be any advantage instead of greasing them but to bond them together? I'm sure Locktite would have an appropriate substance which would lock the two together? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18050
I really don't think it would last. I once tried Loctiting the drive flanges onto the ends of the halfshafts thinking it might reduce fretting. It did, but only for a couple of miles.
I wondered about the feasibility of cross-drilling through the whole joint and pinning or bolting through it. |
| nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174
What are the two studs welded on to the coupler for? To get the coupler off and is that the only way? What if you just want to grease the coupler? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
Could use something a bit more flexible? But maybe that would just wobble, wear and fall out as dust.
It can't be the only way, my local bloke with a garage called Tim managed to change mine without them. He's not a Land Rover guy, just a useful bloke. |
The correct way is to use a special tool to hold it while undoing (or doing up) the retaining bolt or screw, and then to use a conventional puller to pull it off the gearbox splines.
I shudder when I see some of the blacksmith bodgery used for some jobs! |
| Shax Member Since: 05 Oct 2010 Location: London Posts: 391
They were welded on by the fitters to pull the duff coupler off.. looks drastic, but it works! One thing to make sure is that you do not nick the oil seals when fitting... The newer kits have been modified to reduce the likelyhood of this happening, but lets be careful eh!!! ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
An update as it came apart today - seems a pretty bad example compared to some others I've seen on here...
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
| Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630
Wonder how long before one of these units fail and somebody gets seriously hurt... All for the sake of some accountant saving 2p per vehicle... I'm frankly shocked LR don't do a safety recall...
Imagine the field day the press could do with this known fault.... Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
| MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 270
what grease were you using? 1953 80" 1987 mini city e 2011 90" |
Tried pretty much everything. Caterpillar desert gold lasts the longest but still not the answer. Unless you can keep greasing it periodically it'll just dry out and wear no matter what you do. FYI some of our site vehicles were lucky to get 5000 miles out of a shaft. Rubbish bit of design. The casing between the two boxes should be sealed and full of oil.
| MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 692
Using Loctite - look at the Discovery 2 halfshafts. They are loctited to the hubs. But it was designed this way. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
| defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629
Is this still a problem with the latest vehicles 14, 15 and 16 plate or have LR fixed it?
| All times are GMT |
