![]() | Home > Technical > rear ARB balljoint pins taper angle |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
Are you using genuine LR ball joints? Because would rust eating away at the taper not eat away at it evenly? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
If you're stuck you could always measure the ball joint taper with a vernier and calculate using trigonometry.
Just a thought if you were feeling mathematically minded today ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17887 ![]() ![]() ![]() |
Yes, genuine, but rust makes a smooth surface un-smooth, so the balljoint pin doesn't go as far into the hole as it should.
Indeed, but the taper is slight, probably around 1 to 1.5 in 12. Measuing this accurately over such a short length (or more specifically, accurately measuring the length between diameters onm a taper) is difficult, and a very slight inaccuracy in the measurement will make a significant error in the calculated angle. If, as seems likely, no-one knows, I'll either drop a line to someone who makes weld-on brackets in the hope that they'll tell me, or just try some different tapers in a piece of gash plate with engineers' blue until I find the angle. failing that I clear the hole up carefully with a file - it's only an ARB after all, not a steering joint! I was hoping for the lazy and quick approach - to ask someone! Thanks all anyway. ![]() |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1488 ![]() ![]() ![]() |
ARB bush taper spec is 11.42 Degrees inclusive angle, 1 in 10 taper (per side).
Diameter sizes at either side of the bush are 14.27 & 17.42mm |
![]() ![]() Exactly what I needed, very many thanks! |
You're welcome.
We don't make them any more, since January. ![]() |
