![]() | Home > Td5 > fan on all the time |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 ![]() ![]() ![]() |
Evening Ian,
The TD5 has a viscous fan (unless it's been changed to an electric one) so it will be running all the time. ![]() |
yanto Member Since: 03 Sep 2009 Location: caerleon Posts: 230 ![]() ![]() |
At the risk of sounding dum? What is viscous?
this may help you
stigomery Member Since: 10 May 2016 Location: Cambridge Posts: 277 ![]() ![]() ![]() |
*chuckle*
Spot the new Td5 owners (or new to Land Rover Defenders on the whole in my case)... I wondered the same thing, every squeak, rattle, grind, crunch, whir, buzz, rattle... that my new Landy makes I'm wondering, is that normal"... and off to Google we go... So far: - constant fan on - check, that's okay... - something spinning down in the engine bay when I turn the engine off - I thought it could be a knackered turbo, but it's actually the centrifugal filter, that's okay... - glow plugs don't light up/engine doesn't start - turn the immobilizer key you idot! ![]() |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 999 ![]() ![]() ![]() |
Its all good mate that is why places like this exist. Enjoy your new ride.
![]() 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Alfredas Member Since: 22 Feb 2016 Location: Vilnius Posts: 6 ![]() ![]() ![]() |
I had a disco2 td5 and I think it will be the same with the defender if it has air conditioning fitted it will also have two electric fans on the air con radiator. These two turn on then the engine is reaching high temperatures to help it cool down it also switches fan setting to constant in ECU if overheating is logged. You'll have to connect to ECU to turn this setting off.
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Ianto has yours got aircon ?
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 ![]() ![]() ![]() |
I have been looking into this issue as well, as my 2000 Td5 is doing the same. Electric condenser fan is on, constantly. From what research I have found so far, the fan is supposed to come on when the outdoor ambient temperature is above a certain temp, (25 celsius or so) supposedly this works separately from the actual AC system. Mine runs constantly, even in freezing temps, when starting the engine cold. AC on , or off.
No codes, after checking several times. Getting close to just replacing the whole condenser/fan unit, as the fan sounds like it's on it's last legs (I think the bearing is getting tired). Very interested to hear others experiences and thoughts. it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
This won't log faults, it just changes the setting for cooling assistance.
It is interesting. When I bought my 2000MY last year I could not see that my fan ever came on at all. Checked it with direct cureent and it did indeed work. Checked relay and fuses all good. I now know that it comes on as required when using AC and under higher temps. I am convinced just unplugging it, the realy and removing fuses did something??? Who the heck knows but it works, that's all I care. 2020 range Rover Mk IV Autobiography PHEV
Nope, it is proper basic. Only has fog light switch and hazards lol. And keep fit windows. ![]() |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 277 ![]() ![]() ![]() |
Hi. I had the same problem some time ago. If an over temperature is logged, the air con fans are triggered to run and assist in cooling then, as far as I am aware, they will remain on unless reset via the ECU. I had no codes logged at all in mine and couldn't detect a problem. Finally had the system re-gassed and all good ![]() Tony |
BCdefender Member Since: 26 Oct 2015 Location: Nanaimo Posts: 211 ![]() ![]() ![]() |
1999 Defender 110 2003 P38 2007 RR SC "And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it." My build thread: http://www.defender2.net/forum/topic47750.html |
