Home > Puma (Tdci) > What are these things?
Cupboard
First picture, what is the thing on the left that looks like a bit of scrunched up tin foil, and what's the hat that it goes under? Should the hat be attached on properly rather than just flapping around?
Second, has anyone ever seen a dent in this pulley before, any ideas what has caused it and do I need to be careful when ordering a new one?
Thank you Thumbs Up [/img]
Post #531814 15th May 2016 8:50pm
Pilgrimmick
1st one is a heat shield.
The pulley? Has the engine been out of the vehicle? Is it a replacement, it may have been damaged when fitting. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #531821 15th May 2016 9:00pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
First one is a heat shield that sits over the twin wire electrical plug on top of the bell housing, flywheel sensor.
Common to see them come adrift, or missing.
The alloy pop rivet rubs due to vibration then becomes loose.
Also a cause of an annoying rattle!
Can't say what caused the dent in the tensioner pulley?
Maybe someone had a lever or bar against it at some point??
Or a long shot would be something got trapped between belt and pully while running?
I would go for it being used as a lever point for something.... 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #531823 15th May 2016 9:01pm
ian series 1
Beat me to it Mick! Thumbs Up 80" 80" 86" 88" 90"
Post #531825 15th May 2016 9:02pm
Pilgrimmick
First time in a long time I have beat anyone to anything!
;-( 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
Post #531827 15th May 2016 9:07pm
ian series 1
Rolling with laughter 80" 80" 86" 88" 90"
Post #531832 15th May 2016 9:13pm
I'd say the same for the pulley, it's right next to the pretensioner so you need to use a lever to remove the belt.
However, looks like it wasn't done carefully and who ever it was was forceful and crack handed.
I used a crowbar on mine to remove the drive belt myself and never caused anything similar.
I wouldn't worry about it at all though if it's just the edge of where the belt is, looks just like the very outer edge.
LR would probably want £100 for a new one. Rolling Eyes
Post #531836 15th May 2016 9:28pm
Cupboard
It's running on the back of the belt and doesn't seem to be causing any issues. I'm just not particularly happy with knowing there's something not right! Engine has never been out that I'm aware of.
So are you saying the heat shield isn't needed? It seems to be trying to make a bid for freedom Laughing
And what about the bit of scrunched up foil that goes under it?
Thumbs Up
Post #531871 15th May 2016 10:39pm
My Puma has been miising the crankshaft position sensor heatshield for at least the last 150,000 miles, so I don't think you need worry too much.
Post #531873 15th May 2016 10:52pm
miker
Looks like the sort of dent I'd inflict when going for something with the size 1 adjuster and missing to be honest. I wouldn't be worrying.
Post #531883 15th May 2016 11:19pm
