Home > Puma (Tdci) > Defendoor alternative
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
Are there any better alternatives of Defendoor fuel cap cover?
Mine has deformed on +40 temperatures:
 Janusz
www.yahodeville.com
Post #531633 15th May 2016 8:45am
Venomator
Crikey bob...
Not seen that reported before... Shocked
Fortunately I am unlikely to be bothered by such heat... Rolling Eyes
Have you been on to the supplier/manufacturer... Mr. Green
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #531638 15th May 2016 9:04am
keith
Make your own . 2mm Ali and some rubber edging ?
Post #531642 15th May 2016 9:14am
leeds
Likewise I have never seen a Defendoor distort like that.
Now you said the temperature was +40C, now was that air temperature or what? If say air temperature and the full sun was on that side of the vehicle the Defendoor could have experienced a higher temperature, how high would be sheer speculation but could be an extra 10 degrees, however I would be doubtful if it reached an extra 30-40C
According to the Defendoor website the LDPE (low density polyethylene) has a workable temperature range of -40 to +80C. Am not sure if that is the same as dimensionally stable temperature range.
I would image that there has been a temperature gradient across the Defendoor which has released some of the stresses from the vacuum forming process.
My suggestions would be to ask your supplier for a replacement one or to place it in an oven on a flat plate with a weight on to flatten it and raise the temperature to say 70C allow time for it to reach equilibrium temperature and then slowly cool it. It may well recover its shape.
Alternatively send us your address via pm and I will stick a replacement one in the post to you.
Brendan
Post #531656 15th May 2016 9:43am
RED-DOT
I bought one of these and it did the same in the tropical heat of Central Scotland to the point it started popping off the vehicle at the pumps. I reckon it would eventually have folded its self in half but i binned it before that happened. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #531663 15th May 2016 10:05am
Retroanaconda
What does it do? Apart from being something to forget at a petrol station?
Post #531672 15th May 2016 10:30am
Riccarton
Scotland 2012 Defender 90 Puma 2.2 HT Zambezi Silver
It streamlines your Defender and makes it faster Thumbs Up Rolling with laughter Rolling with laughter
Post #531699 15th May 2016 12:21pm
rossy
Blimey, I wish we had that problem here in Ireland. Mind you it was a balmy 20 deg here today - too warm !
Anyway those things are only a fiver or so aren't they Rolling Eyes
Post #531758 15th May 2016 5:03pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
You could always fit one of these as per the winter/water Wolf.
 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #531766 15th May 2016 5:21pm
The main benefit I have it for it that it stops sticks getting jammed in there when green laning etc.
It'd brush off and by the side but if something got hooked in there it'd cause some damage, especially at the wrong angle.
If they were any more cost than they are and the fact they can vanish I wouldn't have one.
I had one fly off once never to be seen again, this one is tethered so has to do as it's told Rolling with laughter
Post #531770 15th May 2016 5:34pm
yaho
Brendan, it was outside air temperature last summer. Intake air temperatures (read by Ultra Gauge) were exceeding 50'C. The plastic cover was deflecting slowly, it took two or three weeks to come to the shape as on the picture.
I think the plastic processing is to blame, as you wrote. I'll send PM. Thank you! Thumbs Up Janusz
www.yahodeville.com
Post #531833 15th May 2016 9:18pm
jimbob7
Re: Defendoor alternative
Carpet Laughing ?? Seriously,in hot sun metal bodywork can take your skin off,not surprised it can melt plastic.
I guess the soft(er) flexible plastic is gonna be more vulnerable than the rigid plastic LR use on the grilles.
http://www.tom-morrow-land.com/tests/cartemp/index.htm Pov.spec,ftw. 2006, 110,TD5.
Post #531926 16th May 2016 10:26am
Naks
It gets up to 45C here in summer, and my Defendoor has been on my 90 since 2010 and no issues. Shocked --
Post #531935 16th May 2016 11:04am
