Home > Wheels & Tyres > 35" Road tyres
Pilgrimmick
35" Road tyres
Wondering if anyone can help me. I have a 90 that has a 2" lift and runs on 35" Simex extreme Trekker. Is there a similar sized more road biased tyre that I could fit when the Simex are not needed? Preferably without breaking the bank!
Cheers 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #531479 14th May 2016 12:53pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I'd look for bfg all terrain as they are meant to be decent tyres and I'm guessing will be around 140 a tyre for yours 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #531492 14th May 2016 2:08pm
miker
What size is that in metric?!
Post #531493 14th May 2016 2:40pm
Pilgrimmick
The Simex are 35x10.50x16
That equates to 280x85x16
Cheers 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
Post #531500 14th May 2016 3:29pm
miker
265/75/16 All terrains would be OK I'd have thought. That's what I have now and will be sticking with.
You could go down to a 235 Continental if you wanted something truly road biased!
Post #531515 14th May 2016 5:24pm
Pilgrimmick
They would be far too small. They would stand at 31.5 inches tall.
Need something that is about the same size to fill out the arches. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
Post #531539 14th May 2016 7:30pm
Cupboard
I've been trying to find a narrow 33" all terrain and struggling. I've seen BFG KO2s in 285/75/16 which is 33", and they claim to do a 35*12.5*15 too.
I don't know why it's so hard to find narrow ones.
Post #531552 14th May 2016 8:52pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
You can get 255 85 16 which is 33" and narrow in bfg mt, although they are muds they stil, have very good road manors 2004 TD5 Defender 90 xs station wagon
Post #531563 14th May 2016 9:56pm
Pilgrimmick
Michelin do the mud tyre ( XZL?) in 8.25x16 that is32.5" tall and fairly narrow. Military use them on the pinzgauer. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
Post #531572 14th May 2016 10:23pm
Cupboard
Yes, it's an XZL. They're a Censored to find though and pricey when you do, and XZLs are seriously noisy!
Post #531721 15th May 2016 2:47pm
Bps
I run 35 12.5 r15 km2s all the time. On 8" rims they fill the arches nicely
Post #531723 15th May 2016 3:05pm
Bps
Keep an eye on eBay there seems to be a few sets crop up on there more regularly now d44 forum has ended
Post #531725 15th May 2016 3:06pm
LANDROVER
How does it handle on the tyres you have fitted? With them being so wide does it try and follow the camber of the road badly?
What tyre pressure do you run?
I have 13.5" wide Maxis tyres currently.
Thanks. Thumbs Up
Post #532537 17th May 2016 10:51pm
Bps
I find them fine on the road, don't wander or pull particularly. I used to have them on 10 wide rims and found that they did pull a lot under breaking. Tried all sorts of stuff and in the end got advised to try 8" rims so the tyre had more of a curve to the tread as on 10" wide rims the tread was pulled very flat and it drove spot on on the 8's. I tend to run around 32psi on the road. What maxxis are you running ?
Post #532544 17th May 2016 11:12pm
LANDROVER
Thanks for the reply,
They are Maxis Mudzilla. They are on wide wheels that have alot of offset, I increased the tyre pressure to 30 and it is just as bad.
I have quite an amount of wandering and also on braking it gets a bit interesting! I changed my trailing arms bushs because it felt like rear steer!
They are quite an agressive tyre and seem to do the job off-road.
I will have to try some other wheel/tyre combo as I can't live with the way it drives. My series 2 drives alot better!
Even at low speed it feels fairly awful. Sad
Post #532548 17th May 2016 11:36pm
