![]() | Home > Off Topic > Dinitrol on lawnmower deck |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
It will dry, so can't see any issue.
It's a good idea, I intend to do the same myself over this coming winter. We have a Honda, but a small hole or two appears in the deck so will need rubbing down, repair and filling. Painting and undersealing. I'd also consider using stonechip first too. Nothing can stick any more than wet grass would already anyway so it wouldn't be a concern of mine. |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317 ![]() ![]() ![]() |
Cool.
Had pretty much decided to give it a try anyway Will look at getting some stonechip too. Its new so thought this would be a good time to protect it |
It would indeed, you need to stonechip first though and you'd have only one opportunity.
A little costly but I would personally use Autotek etch primer, then Autotek stonechip and finally the Dinitrol. I'd say amounts wise. 1x 2x and 2x. Aerosol would do and total cost probably about £40. Then you could ACF 50 the winter bits for extra protection too as well. ![]() Please add some photos once done if you proceed. ![]() |
Job done
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Proper job!
Distorted Vision Member Since: 02 Jul 2023 Location: Cheshire Posts: 8 ![]() ![]() |
I know this is an old thread but I need to do my Mountfield lawnmower. I was just wondering what products you used and in what quantities?
Many thanks!
As steve suggested above - Sand down completely and then 1 coat etch primer, 2 coats stone chip paint and then 2 coats of Dinitrol. Cannot remember what brands of primer or paint I used.
Great - thanks!
I applied Autotek Stoneguard over Etch Primer which was applied on clean bare metal. There appears to be what looks like crazing in a small area. I was just wondering what has caused this for future reference. It's the first time I've ever used spray paint. I allowed 24 hours for the Etch Primer to cure as per the instructions. Would you advise sanding it down with wet and dry sandpaper? If so, what grit would you recommend?
![]() Click image to enlarge [/img] |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2025 ![]() ![]() ![]() |
Funny enough swapped my Honda izzy deck this week! It rusted out in 16 years so pretty good really.
I applied a coating of Gtechnic ceramic and a top coating. Don’t know how long it will last? But it lasts another 16 years I’m ok with that ![]() So easy to clean now though! 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
I'm into detailing and use some Gtechniq products. They make some great products but too expensive to use on my Mountfield lawnmower.
Yeah it's good stuff i have a fair bit in the collection over the years.
didn't use much tbh, i wanted to give it a clean smooth surface so it would wipe down easier and not hold on to debris, I'm sure the routine of cleaning it will go out the window soon enough ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Finally finished this little project with the nice weather these past few days.
Start ![]() Click image to enlarge Stripped to bare metal ![]() Click image to enlarge Masked up and ready to go ![]() Click image to enlarge One coat of Autotek Etch Primer ![]() Click image to enlarge Two coats of Autotek Stoneguard ![]() Click image to enlarge Two coats of Dinitrol 4941 Corrosion Protection ![]() Click image to enlarge Masking removed and blade back on ![]() Click image to enlarge Done. |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5347 ![]() ![]() |
not a bad job that at all,
![]() A youtuber i sometime watch repairs lawnmowers, from the engine to the decks. Pays peanuts for the lawnmower, spends a few hours and its back up and running again. ![]() Friend of mine took the mick out of his next door neighbours, He fitted a stiffer spring or something like that to his, to make it sound more aggressive. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
