![]() | Home > Technical > 110 one piece drive shafts |
| jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790
Hi Tim
You should try these guys, we used them to build HD props for the Bowler http://www.propshaftservices.com HTH John 2014 110 2.2TDCi XS Station wagon - GONE 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - GONE 2024 110 D250 X-Dynamic HSE |
| Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630
Thanks John... But thats the prop shaft... I'm after the drive shafts (one piece)... I can find them for a 90 but not a 110... Or can you use the same part?..
Cheers Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Hi Tim. Wondering if we are having a cross globe terminology issue here... Are you referring to the half shafts (diff to drive flange? Or the drive flanges themselves?
Did LR ever fit the one piece half shafts to 110s? If not are they rated high enoug for them? Generally for cheaper parts you are best going to someone like Paddock Spares or LR-Direct. Most will do international postage. |
Probably a language barrier.. I'm UK based, So no international postage required.... I know LR changed to the single piece 1/2 shafts for the last year of production... My Bowler 90 has them (single piece) and I can get the LR part number for the single piece shafts... However at £289+vat Each I was wondering if there where any cheaper alternatives.
| Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006
Same part 90 or 110. They're flipping expensive as you know. I'm trying to find them cheaper as well will keep you posted
| Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532
24 spline, one piece half shaft, like this?
That's them...
Yea, they are available aftermarket for £90 a pair...
I keep a pair on the shelf at any time |
| sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1250
You can pick up a pair of Ashcroft half shafts for that price (£300). Think that was for a Salisbury axle as I was looking recently.
Again I was looking at something different. Doh Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
| JoeLouw Member Since: 09 Mar 2017 Location: PTA Posts: 5
Hi Guys
OK so I came across this forum post in my search - so maybe this is not the right place to ask this, but I like top know what are the difference between these two images. According to me, the Defenders come out with both Front and Back wheels/shafts looking like my sample photo - Front FRONT
BACK
Joe |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
The front has a seperate half shaft and drive flange, and the rear is a one piece halfshaft and flange Ray
OK thanks for that info. I thought it might be one piece vs not one piece. But what does it do or benifit me to have one piece halfshaft?
Having a one piece shaft and flange at the back just makes one less place for there to be slack in the driveline Ray
Had a pair delivered yesterday, to replace one of my worn shaft/caps
| All times are GMT |
