Home > Td5 > Running cables from cab to engine bay
Loz2286
Excuse the stupid question again, this is so much easier on a series... What are the easiest routes to pass cables from the cab through to the engine bay without significant modifications? I tried running a cable through the washer pipe holes behind the speaker pod to no avail. Couldn't get anything through and I was worried about holing the pipes. Any other good ways through?
Thanks. 1999 Td5 110 CSW
1961 Series 2 88 LPG
Post #530341 10th May 2016 10:45am
ibexman
Behind fuse box main loom 👍
Post #530343 10th May 2016 10:52am
ibexman
Heater cable holes /aerial hole?
Post #530344 10th May 2016 10:55am
MartinK
I used here (borrowed pic):
On mine there were some "spare" points which I cut to let the new cables thru.
a wire coathanger helps with routing.
You can just about (on a Puma) get your hand there from the inside above the brake/clutch pedals...
another borrowed pic:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #530351 10th May 2016 11:23am
MartinK
Chop off an unused "slot" (as circled) and use that - seems best way... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #530353 10th May 2016 11:30am
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
+1 for the bulkheac dromet route, i have run wires for roof lights and loom for my arb compressor and air locker Thumbs Up 2004 TD5 Defender 90 xs station wagon
Post #531364 13th May 2016 8:58pm
