Home > Td5 > TD5 throttle modes
lightning
TD5 throttle modes
Is there any way to stop the throttle on the TD5 Defender from defaulting into a more progressive mode after hard acceleration?
All 3 of my TD5's have done this and it resets after turning the engine off and back on.
I'd rather it stayed in the more responsive mode where you don't have to press it so far to get the turbo to kick in.
Post #531309 13th May 2016 5:22pm
simon67
England 2004 Defender 90 Td5 HT Rutland Red
I have never had this, but will give it a go over the weekend
Assuming you just give it a load of welly in second or third?
Post #531312 13th May 2016 5:50pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
disconnect the two wires on the transfer box from the side. The two on the back are for the diff light.
I've disconnected mine and it defaults to the full power mode as it only works when in low range 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #531324 13th May 2016 6:29pm
gazman
Post #531339 13th May 2016 7:20pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
If you are going down that route of having the throttle response altered by removing the wires, you might as well adjust the throttle respond section if you have a nanocom. It can be considered as part of a remap.
I've used this method to over come a bad spot on the pedal tracks, but I know I need to fix that some day. The defender has migrated, leaving the owner behind.
Post #531788 15th May 2016 6:53pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
There are two throttle modes which are controlled by a switch in the gearbox that detects low range or high range, this doesn't sound like your problem.
Because it's happening after hard acceleration it sounds more like the ECU is going into safe mode which means something isn't right. most of the time it will be the turbo wastegate seizing up and allowing too much pressure (which is detected by the MAP sensor??) so the ECU limits power until you turn the ignition off and back on again. Fixed mine with WD40 and a hammer Very Happy
If you feel like low down power is missing, you might also have a stuck EGR valve, which you should get blanked off anyway Twisted Evil
Post #531818 15th May 2016 8:57pm
