![]() | Home > Puma (Tdci) > Squealing brakes |
stones between bake discs and the stone shelled or pads fitted wrong way round i.e. with leading of the pad upside down and with out copper grease
also if your not happy with the service proved by your garage try new garage Last edited by dorsetsmith on 12th May 2016 10:24am. Edited 3 times in total |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532 ![]() ![]() ![]() |
My 110 was screaming like a
![]() Had a seized piston in one of the rear calipers. Freed off, clean and grease the pads, and all sorted ![]() |
Fozzauk Member Since: 05 Feb 2014 Location: Derbyshire Posts: 272 ![]() ![]() ![]() |
They are usually pretty good at resolving things but I can't see how many times they can strip and rebuild the brakes and expect a different result to the last time?
Surely a piston shouldn't have seized on a 6 month old defender! Actually it is a land rover after all ![]() The squealing seems to be at its worst when I have been on the motorway for a while and then come off to stop on the slip road. |
brake pads stinking in the calipers witch is made weirs by heat i.e. thermal expansion. i had set of pads squealing, the only way i stopped the squealing removed the pads and fitted new set. old set no more than one mouth old from LRJ
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Can you see if they have put copper grease on the pad backs? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
After the last visit everything was covered in copper grease! Apart from the pad surfaces!
Do 130s have a brake bias fitted? 80" 80" 86" 88" 90"
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2149 ![]() ![]() ![]() |
I had this after my last service and it turned out to be the break pads at fault - they were too hard a compound so squealed for about 2000 miles till I had them changed for new Landrover original parts and hay presto - all better and normally returned - as did better breaking and less dust!!
The pads used first time where after market ones and the same ones as I’ve been having fit for years - so no idea if they have changed their compound ... but now all sorted ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
