![]() | Home > Maintenance & Modifications > Air con grille mount fitting advice |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
The piece that's missing is only a bit of strap with a self tapper through the air con nose and another at the back into the wing. Just cut a couple of lengths out of some tin and the jobs a good-un
| HossBog Member Since: 22 Jul 2015 Location: Glos Posts: 131
Thx a lot, I'll get the tin snips out tomorrow. Is the self tapper in the side of the grille mount panel just a standard philips? 2002MY Defender 90 H/T
Yes it is on mine, a black one with a flared out head, like as if it's got its own washer moulded on like a trim fixing screw.
If anyone has got a pic of the fitting it would be massivley appreciated - I'm near a stealer tomorrow and it's always better to have a view of what you're describing to them... 2002MY Defender 90 H/T
| nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174
Try MTC6332, AK612011L and AB614065L. You will also need a flat washer. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
