Home > Maintenance & Modifications > Squeaky serpentine belt.300tdi.
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
This is really doing my head in. Sad
I have changed the water pump...........Twice,thinking it was that squeaking.
Tried the penny trick. Surprised .Made no difference.
Changed the belt.
De gereased the belt & pullys.
The only thing that stops it squeaking is putting talc on the belt,though it will start squeaking again after a while.
Any ideas guys????
Marc
Post #530875 12th May 2016 7:52am
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I had similar a couple of years ago. I too tried the penny trick but it turned out to be the bearing in the the tensioner pulley.
It is possible if you have a good bearing supplier to get a new bearing and swap it out. Also a lot cheaper doing this than replacing the tensioner unit complete.
Regards
Phil 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #530881 12th May 2016 8:21am
sharkey964
Hi Phil
But if it was the bearing in the tensioner,why does the squeak stop when I dust the belt with talk?
Thanks
Marc
Post #530902 12th May 2016 9:18am
300TDi CSW Phil
Marc,
I missed that bit sorry.
One possibility is that the talc lets the belt slide a little without squeeking if it is slightly out of line.
Have you tried cleaning any grease etc off the belt and pulleys?
Regards
M0XQS
Post #530905 12th May 2016 9:24am
sharkey964
Yep,degreased the belt,then replaced the belt.
I think your right,something is running out of line.But I don't know what?
Thanks
Marc
Post #530919 12th May 2016 10:08am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Same problem here but a few quirts of silicone spray settled it down. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #530920 12th May 2016 10:09am
sharkey964
Hi jeffers
Does the squeak come back after a while,when you have squirted it with silicone spray?
Marc
Post #530921 12th May 2016 10:12am
300TDi CSW Phil
Let me see if I can get this in the right order:
Tried cleaning everything down. Still squealed.
Tried Belt anti squeal spray- this worked for a period of time but only days at a time.
Then tried the penny trick. This puts the tensioner alignment back to where it should be when the pivot wears. (the penny is still there) Didn't make a whole heap of difference.
Then took the belt off to clean it again and discovered that the pulley on the tensioner was flapping around like a fart in a bucket.
Replaced the bearing in the pulley and bingo no more squeal.
I'm convinced that it wasn't the bearing making the noise but somehow responsible for something not running true it was a definite belt squeal.
It may be worth taking the tension of the tensioner and checking the bearing on the pulley if only to rule it out.
Regards
M0XQS
Post #530925 12th May 2016 10:17am
sharkey964
Hi Phil
Yes,thats pretty much what I have donn,but not specificaly in that order.
Except,the pully tensioner is not flapping around. Very Happy
& the penny is no longer in.
I'll disengage the tensioner & see if there is any noticable slop in the bearing.
Thanks again.
Marc
Post #530927 12th May 2016 10:22am
jeffersj
Sharkey - had to spray a few times but it finally went. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #531050 12th May 2016 6:15pm
